Digital Art Zone
2 of 3
2
Amy AiMei for DAZ Genesis
Posted: 31 August 2012 11:15 AM   [ Ignore ]   [ # 16 ]
Power Member
RankRankRank
Joined  2011-11-16
Thank you Takeo, but I didn’t misplace the morph. At least not according to either the readme or the other Genesis morphs I have.
Tyvm for the links btw smile
 Signature
Just because I may have a strong opinion doesn’t make it any more (or less) correct than any other, just that I feel passionately a particular way at that moment.
Profile
Posted: 31 August 2012 10:06 PM   [ Ignore ]   [ # 17 ]
Active Member
Avatar
RankRank
Joined  2011-11-16
Takeo.Kensei - 31 August 2012 09:08 AM
Gedd - 30 August 2012 04:36 PM
Ty Takeo, are they both from ShareCG and do you remember artist?
As for the morph, it’s still not showing up. I’m guessing it’s because I’m running 4.0x still and it might only work in 4.5
It should work also with DS4 you must have misplaced the morph
For the freebies, here are the links : Floral Sundress for V4 and Wasg Hair from outoftouch
amy_aimei - 30 August 2012 08:51 PM
Takeo.Kensei, thank you for the nice rendered image.
Gedd, it is designed to work with DAZ Studio 4.5.  I’m using 4.5.0.114.
Sorry! I forgot to modify the scale of the hands and feet. They are bigger than they should be. Please download the file again.  Thank you for testing.
It was my pleasure smile it’s the first time I try to render an Asian type character. There’s still some work to do to get a better skin but it’s a good start for a quick render
I have the same problem as Gedd, and I know I didn’t misplace anything.
Profile
Posted: 31 August 2012 10:07 PM   [ Ignore ]   [ # 18 ]
Power Member
RankRankRank
Joined  2011-11-16
Are you using 4.x or 4.5 DS TG?
 Signature
Profile
Posted: 31 August 2012 10:09 PM   [ Ignore ]   [ # 19 ]
Active Member
Avatar
RankRank
Joined  2011-11-16
4.03
Profile
Posted: 31 August 2012 10:09 PM   [ Ignore ]   [ # 20 ]
Power Member
RankRankRank
Joined  2011-11-16
Yes that seems to be the problem then. Not backward compatible.
 Signature
Profile
Posted: 01 September 2012 05:36 AM   [ Ignore ]   [ # 21 ]
Member
Avatar
Rank
Joined  2012-02-12
It should be compatible but I’ve found out that it effectively doesn’t work. I’ve sent a corrected file to Amy so that she can publish a compatible 4.0 and 4.5 version
 Signature
My Deviant Art
Profile
Posted: 01 September 2012 04:48 PM   [ Ignore ]   [ # 22 ]
Power Member
RankRankRank
Joined  2011-11-16
Thank you Takeo smile
 Signature
Profile
Posted: 01 September 2012 08:22 PM   [ Ignore ]   [ # 23 ]
Member
Avatar
Rank
Joined  2005-04-14
Thank you Takeo.
I have added an updated version at http://www.sharecg.com/v/64489/browse/21/DAZ-Studio/Amy-AiMei-for-DAZ-Genesis-(DAZ-Studio-4.0.x)
I would like to know how can you converted the file for using with DAZ Studio 4.0.x?
Profile
Posted: 01 September 2012 08:38 PM   [ Ignore ]   [ # 24 ]
Active Member
Avatar
RankRank
Joined  2011-11-16
Now it works. cheese
Profile
Posted: 02 September 2012 02:03 PM   [ Ignore ]   [ # 25 ]
Power Member
Avatar
RankRankRank
Joined  2012-04-07
Lovely. Thank you both for the 4.0 edition grin
Image Attachments
Profile
Posted: 04 September 2012 07:03 AM   [ Ignore ]   [ # 26 ]
Power Member
RankRankRank
Joined  2011-11-16
Thank you Takeo and Amy, works great smile
 Signature
Profile
Posted: 04 September 2012 12:54 PM   [ Ignore ]   [ # 27 ]
Member
Avatar
Rank
Joined  2012-02-12
You’re welcome all.
@Amy : I have DS4.0x and DS4.5 on the same PC. That’s fairly easy to convert with that
Btw here’s a little render in blender. Got to work on the skin though
Image Attachments
 Signature
My Deviant Art
Profile
Posted: 04 September 2012 01:12 PM   [ Ignore ]   [ # 28 ]
Active Member
Avatar
RankRank
Joined  2011-11-16
Takeo.Kensei - 04 September 2012 12:54 PM
You’re welcome all.
How’d you pull that off? all of the admins in the previous discussions about 4.5 have said you can’t run both on the same machine.
Profile
Posted: 04 September 2012 03:50 PM   [ Ignore ]   [ # 29 ]
Member
Avatar
Rank
Joined  2012-02-12
Tramp Graphics - 04 September 2012 01:12 PM
You’re welcome all.
I know what they said but that’s possible even if not for everyone. I’m sorry but I don’t want people to mess their install so I won’t give a clue on how I really did that. There are already loads of posts of users having installation or content directory problems But if you want both you could try a virtual machine like VMWare or Virtualbox and share your content directories to feed them.
 Signature
My Deviant Art
Profile
Posted: 04 September 2012 08:31 PM   [ Ignore ]   [ # 30 ]
Member
Avatar
Rank
Joined  2005-04-14
Installing both 4.0.x and 4.5 on the same PC is tricky.  I messed up my installation already.  I’ve to re-install again.  I think using virtual machine may be safer.
I wondered if I just changed the line 2 in the file from
  “file_version” : “0.6.0.0”,
to
  “file_version” : “0.5.0.0”,
will solve the problem of compatibility.  Could someone try?
Patience55 and Takeo, thank you for the nice renders!  Is it hard to fit clothes on my morph?
Profile
2 of 3
2
