Hi,i found out recently the Shade 3d application and because i am using poser i wanted to give a try and play with it.Although it works fine in what i want to do with it,a serious issue came up.Here is what i am doing:
1)i have some figures bought and i open then in shade (as obj format)
2)i do the modifications that i want and i export it from shade as obj and i replace is in the poser data
3)i open poser and i select the figure that i want to from the poser library and i comfort it on a model
4)Now here comes the problem.Although everything works fine,i have problems with the materials.In the material tab i can see all the textures being ok(as they were before i modify the figure with the names of each part of the figure having their own texture) but still somehow the material that shows the render is plain white.what i noticed is that the Preview slot is first on the selection whereas in the original figure is last.I dont know if thats the problem
What i want is to do some modifications in shade(which i have achieved that) and use the material collections that they were included when i bought the figure.Any help will be appreciated ![]()
