Digital Art Zone
No audio playback Studio 4.5 Animate
Posted: 28 August 2012 07:31 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2003-10-10
Was doing some lipsync with studio 4.5 use animate and the audio playback just stopped working?  Studio timeline only works if I click the play button, hitting spacebar shortcut no audio? Using puppeteer in preview mode plays audio.
Any clues?
 Signature
VTV - The Virtual Broadcasting Network
Profile
Posted: 28 August 2012 10:10 AM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  2008-04-10
.... maybe you baked the keyframes?  That will disable all tracks
Profile
Posted: 28 August 2012 04:38 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2003-10-10
Thanks for the follow up, however I didn’t bake the studio keys and just for kicks I loaded a new model, new scene, reloaded studio, rebooted and even reinstalled the latest version of studio 4.5.
The only thing I changed prior to the audio disappearance in Animate was keyboard shortcuts for Animate, Studio nagged me about overriding shortcuts however this had never been a problem in the past. I even went back and restored all shortcuts to defaults.
Any help resolving this would be greatly appreciated, I’m currently working on a project with a deadline.
 Signature
Profile
Posted: 29 August 2012 05:45 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2003-10-10
Just a heads up to anyone who might come across a similar problem. It turned out that I had changed the keyboard shortcut for Animate to the ‘Space Bar’  DS warned me about it being used, however DS usually just over-rights the other shortcut, in this case it didn’t.
The fix or workaround was to add studio keys below Animate, clear the spacebar play shortcut to animate and re-assign it to the studio keys.
Keep rendering…
 Signature
Profile
Posted: 10 October 2012 11:06 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2008-07-18
Hey Virtual Media
Not sure if I’m running into the same problem as you did or something slightly different.
I had customized my shortcuts lie you, switching SPACE BAR to Animate2’s Play button - and have now switched it back to control Play for the regular DAZ Timeline.
The behavior I’m getting though is that if I’m inside of Puppeteer and start to record, I don’t get any audio (My Audio is included via an Audio Aniblock - not sure if there’s a way to include audio on the regular DAZ Timeline in DAZ 4.5 beta, 64 bit - since this does not include the Mimic / Lip Synch options that the 32 bit program does).  I have tried unchecking and then re-checking the box under the puppeteer options menu for Play Audio - and it doesn’t seem to make any difference.
If I click the Play icon inside animate, or the Space Bar, I will get audio which continues to play while I record in Puppeteer but the audio gest choppy and crackly whenever I drag my cursor within Puppeteer.
Don’t know if this is a bug in 4.5 beta or some audio engine conflict - or if there’s a way to get the audio out of animate2 and onto daz timeline which is perhaps part of the problem.  I had been playing my wav files from outside of DAZ but that’s not ideal.  Will probably just ignore the static / crackling and use the space bar.  I’d thought there was an additional problem since puppeteer seemed to be lagging, but changing to less demanding shading seems to have fixed that - plus I’ve got multiple memory hogging programs open at the moment.
Profile
