Digital Art Zone
1 of 2
1
Convert Cyberpunk for M4 Boots to Genesis without crinkles!
Posted: 27 August 2012 11:34 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2005-10-28
1.  Load the boot figure
2.  Make all parts [rTHIGH, rSHIN, rFOOT] of the Right Boot Invisible.
3.  Export the Left boot as an .obj [FILE - EXPORT], give the file a descriptive name.
i.e. “CP Boots Refit to Genesis Left Foot.obj” OK, it’s long, but there’s no mistaking what it is.
4.  In the Dialogue Box Choose “DAZ Studio” in the To:
(Note that it will change back to custom in the next step)
5.  Make sure the following are Checked:
Ignore Invisible Nodes
Write UV Coordinates
Write Normals
Write Object Statements
Write Groups
  Use Existing Groups
Write Surfaces
  Write Material Library
  Collect Maps
6. Cick on Accept; Choose FILE—NEW to clear the scene (no need to save changes)
  Click in FILE—IMPORT; Choose the OBJ file just exported; Click on OPEN
7.  Choose the following in the Dialogue Box
Read Groups
Read UV Coordinates
  Read Surfaces
  Read Material Library
8. Click on Accept
9. Choose the prop in the SCENE tab
10. Click on EDIT—OBJECT—RIGGING—CONVERT PROP TO FIGURE
11.  Choose the following in the dialog that appears
Root Bone Name: hip (I believe these are defaults…)
  TriAx Weight Mapping
  Remove Source Prop
12.  Click on Accept
13.  Load Genesis Base Figure
14.  In the Scene tab, select the Boot
15. Click on EDIT—FIGURE—TRANSFER UTILITY
16. Choose these options
Source
  Scene Item: Genesis
  Item Shape: Default
Target
  Scene Item:  The boot
  Item Shape: Default
Projection Template: None
Show Options
  Smart Left/Right Filtering
  Weight Maps
  Selection Map
  Face Groups
  Region Groups
NOTE:  Deselect MORPH TARGETS, PROJECTION TEMPLATE MORPHS, and FIT TO SOURCE   FIGURE
17.  Click on Accept
18.  Change the color of the Genesis figure to RED or some other easy to see color using the SURFACING|RENDERING activity tab
19.  Enter the following values for the Parameters of the boot
Make sure that it is FIT TO: NONE
  Main Figure
  X Translate: 7.35
  Y Translate:  -1.83
  Z Translate: 7.23
  X Rotate: -22.22
  Z Rotate: 5.85
  Left Thigh
  Bend: -15.61
  Left Shin
  Bend: 34.34
  Twist: -1.04
  Side-Side: -1.17
  Left Foot
  Bend: -19.77
  Side-Side: 7.28
20.  These are the parameters I used, hopefully they work for you, too.  On some tries, I wasn’t able to eliminate all of the poke through, so you may have to toy with it, just in case.  Note that smoothing will be added later on, which should take care of any small poke through you can’t eliminate.  Two other important things to note are that the character’s foot should not be in the “sole” of the boot and both boots (the Right one is done in steps coming up) are at the same height (Y Translate dial).
21.  Delete the Genesis Figure
22.  Select the boot, Choose FILE—EXPORT
23.  Give the file a descriptive name (CP Boots Refit to Genesis Left Foot modeled to Genesis)
24.  In the Dialogue Box Choose “DAZ Studio” in the To:
25.  Make sure the following are Checked:
Write Normals
Write Groups
  Use Existing Groups
Write Surfaces
  Collect Maps
26. Click on Accept; Choose FILE—NEW to clear the scene (no need to save changes)
27.  Choose the following in the Dialogue Box then click on Accept
Read Groups
Read UV Coordinates
  Read Surfaces
28.  In the Scene tab, click on the Prop just Loaded
29.  Click on EDIT—OBJECT—RIGGING—CONVERT PROP TO FIGURE
30.  Root Bone Name: hip (I believe these are defaults…)
Remove Source Prop
31.  Click on Accept
32.  Load Genesis Base Figure
33.  In the Scene tab, select the Boot
34. Click on EDIT—FIGURE—TRANSFER UTILITY
35. Choose these options
Source
  Scene Item: Genesis
  Item Shape: Default
Target
  Item Shape: Default
Show Options
  Weight Maps
  Selection Map
  Face Groups
  Region Groups
  ADD SMOOTHING MODIFIER
NOTE:  Deselect MORPH TARGETS and PROJECTION TEMPLATE MORPHS only!
36.  Click on Accept
37.  In the Scene tab, delete the Genesis figure, then select the boot again
38.  Click on FILE—SAVE AS—SUPPORT ASSET—DSF FIGURE OR PROP FILE
39.  Choose a Save location (Will vary if you’ve customized your setup, as I have)
I’m using this one that I created—
  \Documents\DAZ 3D\Studio4\My Library\!Custom Content\Figures
40.  Choose a File Name (CP Boots for Genesis Left Foot.dsf)
41.  Click on SAVE
42.  Click on ACCEPT
43.  Repeat for the other boot, using these values in Step 19.
  Main Figure
  X Translate: -7.35
  Y Translate:  -1.83
  Z Translate: 7.23
  X Rotate: -22.22
  Z Rotate: -5.85
  Right Thigh
  Bend: -15.61
  Right Shin
  Bend: 34.34
  Twist: 1.04
  Side-Side: 1.17
  Right Foot
  Bend: -19.77
  Side-Side: -7.28
The boot should follow and smooth to all of the shapes in the Genesis Actor parameter.  Even Freak 3 looks acceptable!
Please note that there is a simpler version of this method that worked for both pairs of footwear from Captain Runner and Captain Rebel.  As soon as I get a free moment, I will list those steps here, too.  Essentially you can skip the beginning part where you export each shoe as a separate obj and reimport them and make them a figure.  The Captain footwear is able to be posed to match up to the Genesis feet without the extra step.  Again, I’ll redo it (probably after I upgrade to DS 4.5) and post the steps.
BTW,
This work is based on procedures previously presented by others in the forums and a specific comment by somebody about posing the footwear to match Genesis.  When I run across those posts again, I will properly credit them.
Hopefully this works for everyone interested in trying as it did for me.
Attached is Genesis with Freak 3, Michael 5 Hero, and Hiro 3 dialed up, wearing the Cyberpunk boots.
Image Attachments
Profile
Posted: 28 August 2012 01:47 AM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  0
You can save using a lot of export/import settings by just using Hexagon.
Studio can send to Hexagon and Hexagon can send to Studio without worrying about settings.
You don’t even have to learn Hexagon you just have to click one button to send to Studio.
Profile
Posted: 28 August 2012 04:14 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2005-09-19
graham james - 28 August 2012 01:47 AM
Agreed, I’ve done this with several items and my Hex abilities are minimal. I’d also recommend creating a pose in which Genesis has its feet superimposed over the feet of the character you are converting from, which should save all the translation etc - just fitting the shoe to the donor puts it in the right position to export, import and have the obj sitting in the right position on Genesis.
OTOH for softer or flatter soled shoes - essentially anything that fits closely to the foot - it may just be simpler to use autofit, or convert to weight-mapped and push through the transfer tool and accept a small amount of crinkling.
Profile
Posted: 28 August 2012 05:18 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
If a procedure like this will work, couldn’t the Transfer Utility be programmed to use it, or better yet, AutoFit?
Profile
Posted: 04 September 2012 02:06 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2005-10-28
This should work for anyone that doesn’t have Hexagon.
But for those that do, which specific steps are replaced by sending to Hexagon.  And what are the specific steps for doing that?
Thanks!
Profile
Posted: 04 September 2012 02:11 PM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2005-10-28
DWG - 28 August 2012 04:14 AM
That’s a good idea.  I’ll try that when I get a chance…
The whole point of doing it is I don’t want ANY crinkling.
Profile
Posted: 05 September 2012 12:30 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2011-11-12
Close but no cigar. I must have missed something. I’ve been toying (bumbling) with a similar method and had little luck, so this is just what I’m looking for. I tend to attempt a reinvention of the wheel when it comes to these things so I haven’t seen the other similar threads about.
I would love to be able to use all my old favourite boots. Ah! Just noticed the mesh goes to hell when I add the smoothing modifier. I think it has something to do with the last export into/out of Hexagon (I had to do it twice for the same figure). A damn shame that a simpler “click and done” autofit hasn’t been developed for boots yet. The market for a script/plugin would be hungry indeed.
Image Attachments
 Signature
My 3D/DAZ blog
JimZombie on deviantART.
Profile
Posted: 05 September 2012 05:43 AM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Looks as if there are unwelded vertices somehow - which boots are these?
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 05 September 2012 07:34 AM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2011-11-12
They are the cyberpunk boots. I haven’t had a chance to try from scratch again, but I’m fairly sure it won’t happen again.
 Signature
My 3D/DAZ blog
Profile
Posted: 06 September 2012 01:40 AM   [ Ignore ]   [ # 9 ]
Member
Avatar
Rank
Joined  2005-10-28
I didn’t use Hexagon, so I don’t know what’s causing the problem you’ve pictured.  At which step is this?  Did you also try it without going into Hexagon?
Profile
Posted: 06 September 2012 01:41 AM   [ Ignore ]   [ # 10 ]
Member
Avatar
Rank
Joined  2005-10-28
BTW, are these steps easy to follow?  I really tried to be thorough…
Profile
Posted: 06 September 2012 02:38 AM   [ Ignore ]   [ # 11 ]
Member
Avatar
Rank
Joined  2011-11-12
No, the problem isn’t Hex. I didn’t have trouble till I needed to export the boots a second time (I accidently exported an additional primitive the first time). Something happened to the materials - all the missing parts somehow ended up as a unique material.
I did get lost a couple of times after step 20 or so, but I got the gist of what I had to do as I have some experience from playing with the tools myself.
Thanks by the way, it is good to have a practical solution to the problem of auto fitting boots. I’ll let you know if I get it worked out. Actually, I may go and try it right now.
 Signature
My 3D/DAZ blog
Profile
Posted: 06 September 2012 02:58 AM   [ Ignore ]   [ # 12 ]
Member
Avatar
Rank
Joined  2011-11-12
The problem was exporting from Hexagon. I had the wrong settings (just happened again but have since changed options and got good export). I think your method would be as quick really. The import/export doesn’t take as long when you know what you are doing, but can look complex to the newb.
 Signature
My 3D/DAZ blog
Profile
Posted: 06 September 2012 03:40 AM   [ Ignore ]   [ # 13 ]
Member
Avatar
Rank
Joined  2011-11-12
And here it is, the sweet stench of success. Many thanks Supercope wink
Image Attachments
 Signature
My 3D/DAZ blog
Profile
Posted: 06 September 2012 07:52 PM   [ Ignore ]   [ # 14 ]
Member
Avatar
Rank
Joined  2005-10-28
jimzombie - 06 September 2012 03:40 AM
AWESOME!
Profile
Posted: 07 September 2012 12:03 PM   [ Ignore ]   [ # 15 ]
Member
Avatar
Rank
Joined  2011-11-12
I linked back to this thread from an image I posted on deviantArt. http://jim-zombie.deviantart.com/#/d5e054m Couldn’t help but show my regenerated boots off.
 Signature
My 3D/DAZ blog
Profile
1 of 2
1
