Hello, I try to load the item DeliveryDriverForGenesis in Daz Studio 4.5 but nothing happens, it appears in the list of scene but is not displayed in the viewport.
Anyone else had this problem?
Thanks
You have to Select Genesis first in the Scene tab, then double click, or drag and drop, the item onto Genesis.
Whether or not Genesis is selected shouldn’t make a difference, the clothing should load in both cases, but if Genesis isn’t selected it won’t be automatically fitted to him.
Everything loads but not the pants and shirt.
The cap, the shoes, the props load perfectly.
But not the pants and shirt, the guy was right it appears on the scene tab but not in the viewport.
I even went as far as trying to render it to see if it would only appear in the render image but it does not either.
Please help.
Thank you.
By the way I’m a beginner. If you could explain it in simple terms.
This is a problem I encountered on some other products. If you look, the outfit is most likely listed in your scene tab but there is nothing at all in surfaces when you select it. Here is my thread about it and how I “fixed” it. In short, you need to do some creative file editing to tell Daz where the geometry is.
Was busy looking at files in a text editor and didn’t see Riggswolfe’s post.
If you open up the geometry file, you’ll see the id is blank. I went in and added the word “geometry”.
If you open up the ShirtPant file in the People/Genesis/Clothing/...folder, line 24 and 25 need to be edited.
What is circled in red is what the two files should look like after editing.
Looks like you found the same fix I did Phoenix. The odd thing about this issue is that Daz 3 and Daz 4 don’t care about this ID so stuff loads just fine.
Yup…this outfit was created before 4.5, so it used to work just fine.
It gets frustrating when there are obviously some minute changes in the versions that render previous items useless. I have the greatest admiration for plugin creators that seem to have to rebuild their products every time D|S gets an update.
Thanks for posting the link to your thread. That should definitely help some folks out!
I added it to my signature because this is the second thread I’ve seen in two days. The odd thing if you read my thread is that another Daz user didn’t have the issue when using the exact same products I had the issue with. (With one exception.) Our product versions and Daz versions were the same as well.
How do I do this in a MAC with DS 4.5?
Sorry I am not that techie.
I am only using Daz because you simply double click to load characters and stuff.
I don’t know how to do it in a mac but on windows the files can be edited with a text editor generally. Do NOT use something like Word that adds formatted or it will screw things up.
