Digital Art Zone
Daz Studio 4.5 PMD injection?
Posted: 24 August 2012 06:15 PM   [ Ignore ]
Member
Rank
Joined  2011-05-17
The only plugin I can find for this is out of date for 4.5. Is there a script that works or anything? Perhaps someone could tell me how to do it manually, if it is not too difficult?
Profile
Posted: 24 August 2012 07:45 PM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  2009-06-11
I thought I read somewhere that Studio could handle binary morphs natively now.
Profile
Posted: 24 August 2012 08:15 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2011-05-17
That has not been my experience thus far, unless I am doing it incorrectly.
Profile
Posted: 25 August 2012 04:58 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2005-09-19
I’ve had some success with getting PMDs to work, but it’s been patchy in the past. I haven’t done any sort of systematic check with 4.5, but I’ve just confirmed one of the items I fixed is still working - Dirty Eddy’s Glock 21 from Rendo.
The fix was quite simple, change the command inside the PP2 or CR2 to load the PMD from morphPmdFile to morphBinaryFile
So for the Glock
morphPmdFile :Runtime:libraries:Props:DirtyEddysGlock21:V4GlockRThand.pmd
became
morphBinaryFile :Runtime:libraries:morphs:!Rendo Glock 21:V4 Glock Lefthand.pmd
(I took the opportunity to move the PMDs to a directory of their own so I can move the item folder around without things breaking - I do the same with all morphs)
Profile
Posted: 25 August 2012 05:21 AM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
What are the PMDs for? DS should be able to load them from characters and, I think, props but not from poses. However, the syntax has varied a lot over Poser updates and versions so there can be issues.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 25 August 2012 05:30 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2005-09-19
The Glock is a prop, I just checked another item I knew I’d applied the same fix to, but without success, which is also a prop, and still no joy in 4.5.
Profile
Posted: 25 August 2012 07:01 AM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2010-12-25
There is a plugin for DS3 that can load pmd injections but doesnt work in DS4(or not with the DS4.5 beta versions). You can however inject in DS3, then save the figure as daz file, open it with DS4 and use the figure in DS4 with the added morphs through the pmd.
The plugin is called Inject PMD.
Profile
Posted: 25 August 2012 11:14 AM   [ Ignore ]   [ # 7 ]
Active Member
RankRank
Joined  2012-02-04
PMDs in 4.5 is better than it was in 4.0, but it’s still not anywhere close to 100%.
Some of the figure items I had with PMDs that did not work in 4.0 are working now in 4.5.  The two problems I had in 4.0 (depending on content item) were:
1) It wouldn’t appear to link the morph controls to the actual morph data, so moving the slider in the Parameters tab did nothing
2) PMD morphs would cause the item to explode (vertices going everywhere but where they should)
For figures, most of the stuff affected by problem 1 seem to be working now in 4.5 (e.g., some of the older stuff from 3D-Age over at Renderosity).  For item 2, some of the items that used to cause explosion now work, but others do not and still explode (like Exnem’s Armored Witch).
Every single PMD prop I have (fortunately not many) suffered from problem 1, so I don’t know if any of them also suffered from problem 2.  However, in 4.5, despite the one release note entry I saw that said they had ‘fixed PMDs for props’, all my PMD-based prop items are still exhibiting problem 1.
 Signature
My deviantART Homepage
Profile
Posted: 27 August 2012 12:00 AM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2011-05-17
The PMD that I am trying to inject are facial poses for a figure
Profile
Posted: 30 December 2012 01:21 PM   [ Ignore ]   [ # 9 ]
New Member
Joined  2003-10-09
Any update on this?  I have pmds as poses that I’d like to use in DS4.5.
Profile
Posted: 30 December 2012 07:23 PM   [ Ignore ]   [ # 10 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
There is a beta version of the InjectPMD plugin that does work in 4.x (mostly).
There is also a Java app that works nicely…
Keyra posted this in one of the other PMD threads.
http://www.kuroyumes-developmentzone.com/poser/freebies/
And it does work, on Windows, Mac and even Linux.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 04 January 2013 11:37 AM   [ Ignore ]   [ # 11 ]
Member
Rank
Joined  2005-09-22
mjc1016 - 30 December 2012 07:23 PM
How does this work? I’m having trouble figuring it out & I bet I’m doing something wrong. I have a character that the head morphs are pmd & I’m trying her with DS4.5
 Signature
May the hands of fate be kind to you & yours. smile
Profile
Posted: 02 April 2013 05:52 PM   [ Ignore ]   [ # 12 ]
Active Member
RankRank
Joined  2006-02-27
for anyone still wanting to know the latest version 4 works in ds4
I need one specific to studio 3.1.2.32
Profile
Posted: 02 April 2013 06:18 PM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2004-04-25
Paradigm67 - 27 August 2012 12:00 AM
Which product and do you know which version of Poser generated the PMD’s?
 Signature
“...not world enough nor time…”
Profile
