Digital Art Zone
How to poke a see through hole in a cube
Posted: 22 August 2012 03:59 PM   [ Ignore ]
New Member
Joined  2012-08-02
Hello,
forgive the noob question, but could someone help me create a see through hole in a Cube primitive?
(Within Daz studio if possible)
Thanks!
Profile
Posted: 22 August 2012 04:19 PM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
As far as I am aware the only way would be the use of Opacity Maps but doing so you would need to match the UVmapping of the Cube. Best using something like Hexagon and use a Boolean operation. Meaning using a cylinder to carve a hole through a Cube. This then could in thoery be saved as an OBJ Wavefront object and used in Daz Studio.
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 22 August 2012 04:29 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2008-02-24
make 4 rectangular cubes and put them together so you get a hole in the middle smile
Profile
Posted: 22 August 2012 04:31 PM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
ROFLOL not helpful but funny. raspberry
 Signature
Pete
My Render Thread
Profile
Posted: 22 August 2012 05:38 PM   [ Ignore ]   [ # 4 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
Hexagon is the only way I know to do this properly. You should be able to pull it off with a few hours of trying and studying the tutorials.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Profile
Posted: 22 August 2012 06:19 PM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2004-04-14
Jaderail - 22 August 2012 05:38 PM
I agree, use Hex.  You can either cut it out via a boolean cut or manually do it.  Boolean is faster but I had to file a bug report about it the other day and dont currently recommend it.
Go here for free video tutorials - http://www.geekatplay.com/hexagontutorials/begining.php - THe second tut should show you what you want for the easy way (boolean)
And also check out this one for doing it without boolean - http://www.youtube.com/watch?v=thEOkonc_AM
 Signature
My DAZ3D Store
My Free Stuff
My Art @ DeviantART
Ships of the Line - MEGA THREAD
How to use the Poser Format Exporter - **Updated 2013-02-09**
Profile
Posted: 22 August 2012 06:28 PM   [ Ignore ]   [ # 6 ]
Active Member
RankRank
Joined  2012-02-04
Another approach is to use the Polygon Group Editor in Studio.  If you go this route, you will be beholden to the size of the quads that make up the cube’s face, however.  So if you’re using a primitive generated within Studio, make sure to specify a large enough number of polygons for your needs.  Then set the viewport to one of the wireframe modes so you can see the polygons making up the cube’s face and switch to the PGE.  Select the polygons for the hole you want to punch in the cube and then assign them to a new surface.  Then you can hide that surface by setting its opacity to 0.
This only works if you just want a hole in the side of the cube.  If you want to create an extrusion through the cube, then you’ll have to use a proper 3D modelling tool
 Signature
My deviantART Homepage
Profile
Posted: 23 August 2012 05:25 AM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  2008-02-24
Szark - 22 August 2012 04:31 PM
Well it was a try at an idea at least…
Profile
Posted: 23 August 2012 05:52 AM   [ Ignore ]   [ # 8 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Indeed it was. Still makes me chuckle…yes small things amuse my small mind. I wouldn’t have it any other way. My theme tune is Monty Python’s “It’s good to be an Idiot”. smile
 Signature
Pete
My Render Thread
Profile
Posted: 23 August 2012 09:39 AM   [ Ignore ]   [ # 9 ]
New Member
Joined  2012-08-02
Thanks everyone!
Hex we go then. It is a little more work than I anticipated, but it will do exactly what I need.
Profile
Posted: 23 August 2012 12:47 PM   [ Ignore ]   [ # 10 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
opacity ok if you do not need actual geometry
Image Attachments
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
