Another question - is it possible to get and set the values from the ‘Property’ object ? Here is a code (taken from Node Property.dsa in the samples and a little bit edited).
This script will identify and display the Subdivision and Resolution level property. But I can’t find a way to get it’s value or set it’s value!?!!
// Array<DzProperty> :
function getGroupProperties( oGroup, bTraverse, bRecurse )
// Declare an array to hold properties
var aProperties = [];
// If a group isn't passed in
if( !oGroup ){
// We're done, return an empty array
return aProperties;
// If a group is passed in
} else {
// Get the number of proeprties in the group
var nProperties = oGroup.getNumProperties();
// Pre-size the properties array
aProperties = new Array( nProperties );
// Iterate over the properties, setting each element in the array
for( var i = 0; i < nProperties; i += 1 ){
aProperties[ i ] = oGroup.getProperty( i );
// If we are recursing
if( bRecurse ){
// Concatenate the properties array from child groups
aProperties = aProperties.concat( getGroupProperties( oGroup.getFirstChild(), bTraverse, bRecurse ) );
// If we are traversing
if( bTraverse ){
// Concatenate the properties array from sibling groups
aProperties = aProperties.concat( getGroupProperties( oGroup.getNextSibling(), bTraverse, bRecurse ) );
// Return the array of properties
return aProperties;
function getNodeProperties( oNode, bTraverse, bRecurse )
// Get the property group tree for the node
var oPropertyGroupTree = oNode.getPropertyGroups();
// Get the first group in the tree
var oPropertyGroup = oPropertyGroupTree.getFirstChild();
// Get the properties for the node
return getGroupProperties( oPropertyGroup, bTraverse, bRecurse );
// Get the primary selection
var oNode = Scene.getPrimarySelection();
// If something is selected
if( oNode ){
// Get the properties available to the user by way of the selected node
var aProperties = getNodeProperties( oNode, true, true );
// Declare variables we'll be using as we iterate
var oProperty, oOwner, oPresentation;
// Iterate over all properties
for( var i = 0; i < aProperties.length; i += 1 ){
// Get the "current" property
oProperty = aProperties[ i ];
// Get the owner of the property
oOwner = oProperty.getOwner();
// Get the property's presentation
oPresentation = oProperty.getPresentation();
// If the property doesn't have a presentation, skip it
if (oProperty.getLabel()=="SubDivision Level"){
print(oProperty.getLabel());
print(oProperty.getName());
} else if(oProperty.getLabel()=="Resolution Level"){
