I just noticed this in your screen capture. The bottom right morph is loading at Half value when you start DS. I’m very sure you have other morphs that are also loading as SET to ON.
Hi Jaderail, it looks that way, but it is actually 0.00 as are the others, that morph seems to have a minus setting too, it has never affected the default genesis before today when I installed 4.5, cheers tho
Correct - it looks like something you installed (since you didn’t save) may have overwritten your Genesis…. The reinstall should fix it….
Hi Kat, that morph did not affect genesis before today, I have had the default genesis load as it should right up to the install of 4.5 when it has gone ‘pear shaped’ I have uninstalled and installed the new genesis starter file twice now to no effect, going to re-install 4.5 and see what happens.
I had dsf character files (the three mentioned in earlier post) where the dsf morph sliders reside. This seemed to be “confusing” Genesis every time it was being activated in DS4.5 and was preloading one or more of them into Genesis.
Now that I’ve moved those character files, Genesis is working perfectly.
Ok….hopefully that will work.
It didn’t sadly, looks like i’ll be deleting the runtime (only about 17GB), uninstalling and clearing the registry and starting from scratch :(
One thing tho I had the RC3 of 4.5, upgraded to the final release on my macbook pro (snow leopard) and everything is hunky dory (pic attached)
OK, I’m making some progress… I’ve removed three dsf morphs and Genesis now loading as it should.
Subira Gens On
Head Inj (Subira again)
Almond Crush
(I think these were All freebie add-ons to other products)
I’ll check to see if i have these, (tho they don’t ring any bells) before i go the total delete and re-install route.
Why don’t you start simple. Delete your People>Genesis duf file and in your data folder, delete it from there as well. Make a copy of your data folder, if you want to get more aggressive, and go from there. You do not need to remove ANYthing from the registry. There is nothing in there at all that tells DS which Genesis to load. Mainly just make sure you get rid of your Genesis.duf or genesis.dsf files that are hanging about.
Subira Gens On
Almond Crush
Kat
Will try that, Kat, thanks, and then reinstall 4.5 and the genesis starter essentials?
Subira Gens On
Almond Crush
Kat
Yep.
The main issue is somewhere in your content is a leftover genesis file not being replaced, or still hanging out. Any other things, like registry etc….aren’t going to fix it, so no real need to go that deep. It is something simple, just finding where it is can be a pain. LOL
One thing I have noticed is the the icon for Genesis Starter Essentials has an exclamation mark in it.
That denotes an orphan file. A file DS is looking for that it can not find. In the Product view (the a-z list of products), go to Genesis, and if you r-click that icon and choose to remove orphan files, that should go away.
(In that view you screened, you are on Products and not files. It may just be missing the product image as well - choose File instead (top right corner of the pane) and see if you have any !. If so then what I said applies.)
Your base problem is that you downloaded and installed Warrior Princess for genesis (freebie) and the problem is that the author made it autoloading.
So everytime you load Genesis it autoloads the morph
It happens when people create morph with the morph dialed
Thanks so much, part of the problem too was that I have been using the mac recently which didn’t have that warrior princess product installed, hence why i thought it was the 4.5 installer when i put it on the PC, weird thing tho, i did uninstall both versions of warrior priestess (genesis and v4) but it obviously left all the files behind. Anyway all sorted now, thanks again.
Did either of you use File>Save as>Support Assets>Save Modified Assets?
I started to make a pants. Last time I saved and now loaded again. I made some minor changes, like added smoothing modifier and set Iterations and collisions. After when I clicked on save—> modified assets, it told me, didn’t find and modification.
