Digital Art Zone
2 of 6
2
Anybody have advice/ animating walk cycle???
Posted: 23 August 2012 01:48 AM   [ Ignore ]   [ # 16 ]
Active Member
RankRank
Joined  2007-10-15
If you really want to do a walk cycle from scratch (let me guess, he’s gonna suggest you study the basics….) I suggest you do a tiny bit of research. There are a few concepts that are really, really important in understanding how people move. It’s not just a matter of moving the legs, there’s a lot more to it.
Like I say, there’s tons of info out there. I did a couple minutes of searching and found this link which at first glance seems to have the right approach to understanding what’s involved. If nothing else at least spend a few minutes reading thru it, there’s some interesting principles we follow when we move, and knowing them might make your production much nicer.
http://www.fjasmin.net/walk_cycle_tutorial/index.html
Profile
Posted: 23 August 2012 11:17 AM   [ Ignore ]   [ # 17 ]
Power Member
Avatar
RankRankRank
Joined  2006-08-27
Joe, there’s no one here suggesting not to do research, so there’s no reason to act as the long suffering voice in the wilderness that no one listens to. For instance, my posts were more related to the mechanics of saving the cycle in Carrara once the OP achieved the cycle he wanted. Wendy suggested a BVH, which is also a legitimate route.
Hell, I remember re-watching Disney’s Snow White a couple years ago and was surprised to realize They used rotoscoping. There was a group scene and the characters were dancing. It was clearly a rotoscoped sequence, where the rotoscoping was used to help the animators with the movement of the characters. Clearly rotoscoping isn’t motion capture, but it’s an early cousin.
http://en.wikipedia.org/wiki/Rotoscope
Profile
Posted: 23 August 2012 04:11 PM   [ Ignore ]   [ # 18 ]
Active Member
RankRank
Joined  2007-10-15
Dude, I was responding to ps1borg’s very simplistic explanation of a walk cycle. My point was that with 2 minutes of internet searching you can come up with some very nice, very free, detailed explanations of how people walk and move, and if you really want to do it manually there’s a lot more to it than just moving legs in 4 poses. There’s weight, and balance, and emotion, etc.
Why jump on me? I’m trying to help.
How about this: “Cool, thanks for the link, it has some useful stuff that I hadn’t considered”. Y’know, common courtesy.
Profile
Posted: 23 August 2012 04:20 PM   [ Ignore ]   [ # 19 ]
Power Member
Avatar
RankRankRank
Joined  2006-08-27
JoeMamma2000 - 23 August 2012 04:11 PM
My apologies then. BTW, I did study the linked page. Very good points. I found that some of them I already did, just executed poorly.
Profile
Posted: 24 August 2012 03:52 PM   [ Ignore ]   [ # 20 ]
New Member
Joined  2009-05-25
Have you tried puppeteer?  If I was building from scratch this is what I would use in daz
 Signature
Check out the NEPS Production Blog on Facebook
Profile
Posted: 24 August 2012 06:41 PM   [ Ignore ]   [ # 21 ]
Member
Avatar
Rank
Joined  2003-10-10
Well for me its always been useing BVH files in Poser and saveing the info out as a BVH and then applying to the same figure in DS…
I love the Poser’s Walk designer
With the kinetic its a breeze….
With Bvh its just a little tweaking in DS to get it right
 Signature
As Always B3D
My radio Station…
http://www.pandora.com/?sc=qm81447313#/
http://www.myspace.com/foleypro
http://www.michaelhershman.com
http://www.artwanted.com/foleypro
http://foleypro.deviantart.com/
http://brycepd.webs.com/
Profile
Posted: 24 August 2012 09:43 PM   [ Ignore ]   [ # 22 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
I have a slightly different approach to the traditional walk in place then translate, which is very difficult to do without floating and foot slippage.  I use the traditional four positions, but just as the back foot leaves the ground, I move the hips forward to be over the front foot.  That makes an actual step, gives the impression of weight and pushing off on the back foot.  Then it’s easy to measure the length of the stride and match the distance to be walked.
Fully agree that it is a lot easier to do in Studio using Puppeteer because you can match left and right side exactly.  Can’t imagine why they never implemented Puppeteer the same way in Carrara.  Poser’s walk designer is also great.
Profile
Posted: 24 August 2012 10:24 PM   [ Ignore ]   [ # 23 ]
Member
Rank
Joined  2011-05-15
I think regular old Animate/Aniblocks w/ Carrara importer is the easiest way to go. I love ‘em. They’re not super customizable (I’d say just completely delete a limb’s corresponding keyframes if you want to make adjustments to that limb) but the Mixamo website is pretty customizable. If I remember right you can just cue up and adjust the movement the way you want it, save it and then buy that movement.
If you’re really interested in doing it by hand, I ‘d probably just focus on key poses. Get your key poses in, then put a keyframe at the 50% mark between those keys, make adjustments, then put another one at the 50% mark, make adjustments, and then another one and maje adjustments. So if you had, say, 8 key poses, you then multiply by two (16) and then multiply by two (32), then another two (64) easing you tweens along the way. Should get you started in the right direction.
 Signature
Swing by and Subscribe: http://www.youtube.com/dumpprep
Profile
Posted: 25 August 2012 01:31 AM   [ Ignore ]   [ # 24 ]
Active Member
RankRank
Joined  2007-10-15
My fuzzy recollection from the last time I tried to animate a character in Carrara using IK was that I finally threw up my hands in frustration, and decided to disconnect all the IK and just do it by hand. I recall that Carrara is missing some of the basic tools needed to automate and rig the character, and compensating (ie, fighting the IK) is more work than it’s worth.
For example, when you lower the hips on the Z axis you generally want the knees to bend, not lock. And during a walk you want to lock the toe on the floor and raise the heel as the hip goes forward. And you also might want the hips or other body parts to be positioned automatically to maintain balance (eg, halfway between the legs). And so on. BTW, those are probably bad examples, and I’m sure there are ways to get those to happen, but in a general sense, when you’re talking about rigging an entire character’s legs, feet, arms, etc., the rigging tools required become fairly complicated. But with Carrara I recall it was real difficult or impossible to rig that kind of stuff satisfactorily, and I spent too much time trying to fight the IK to make all that happen.
In any case, doing it manually (FK) is too much of a pain with any significant animation IMO, so I tend to write Carrara off for any serious character animation, unless you use motion capture stuff I suppose.
BTW, if anyone’s interested, you can probably do a search for “character rigs” or something like that and find a video of what I’m referring to. There’s quite a bit that goes into a complete rig for a professional animator for the arms and legs alone. Not to mention the facial rigs for eyes, mouth, etc.
Profile
Posted: 25 August 2012 02:50 AM   [ Ignore ]   [ # 25 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
here’s one! that I just got emailed about by papasmrfe who I follow on sharecg!
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 25 August 2012 04:10 AM   [ Ignore ]   [ # 26 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
maybe the hardest thing is stopping the foot slide -
if you use a cube object as a target helper to mark where your foot is at each step it helps a lot
 Signature
http://andrewfinnie.blogspot.com.au/
Profile
Posted: 25 August 2012 04:47 AM   [ Ignore ]   [ # 27 ]
Active Member
RankRank
Joined  2007-10-15
head wax - 25 August 2012 04:10 AM
Is this not fixed by using a linear interpolation on those curves, and making sure the IK target isn’t moving between frames?
Profile
Posted: 25 August 2012 06:28 AM   [ Ignore ]   [ # 28 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
don’t know Joe smile
I admit i’m a crappy animator smile
this is the last time I d id a walk cycle - in 2009 - with morph targets and a hand made mesh
http://www.youtube.com/watch?v=qfo-DRglT9A
 Signature
Profile
Posted: 25 August 2012 08:30 AM   [ Ignore ]   [ # 29 ]
Member
Rank
Joined  2011-05-15
I think it’s also worth noting that it’s probably a bad idea to actually try and incorporate forward movement of the character until you’ve completed your walk cycle. Like just worry about getting him walking in place effectively, then once you have that, you can move and resize your model however to create the illusion of movement. That’s what I always do in Flash and traditional animation stuff.
 Signature
Profile
Posted: 25 August 2012 12:32 PM   [ Ignore ]   [ # 30 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Joe is so right about using Carrara rigs in an animation - which is why I prefer to rig in DS.  What he says about professional riggers is spot on - I saw a video of a professional rigging in Blender and it is very different to what we get with Poser/Daz content - lots more bones, especially in the feet -even bones outside the feet which are not allocated to mesh but control other bones.  Also in the past there was a problem with those default target helpers attaching themselves to other objects in the scene, with really weird results.
Something I picked up on walk cycles is when you make an IK chain, first thing to do is delete the default boxes it makes and replace them with target helper objects.  There is less play and somehow they pin better.
Profile
2 of 6
2
