I’ve a lot of Sixus1 Poser character, but i can’t import tehem in DS4 because whe i try to use them in DS4 the morph don’t work more. Is happened with many of them, and this is the only real reason because i don’t left forever DS3 and don’t start to use DS4.
If you want try, download Behemoth 2, load it in DS4, and try to use some expression morph.
I just downl;oaded this figure, and installed it into My Library. When I select the Head in the Parameters tab, all of the morphs are there, and they all work, I don’t know why they wouldn’t work for you. I am using 4.5.0.114.
a lot changes back and forth during that thread
and sixus1 has said he’d be willing to consider working with a ds content creator with a view to getting figures into studio, so he hasn’t ruled ds out entirely just yet.
His main concern seems to be the amount of work / time versus monetary return to do a poser and a studio version, which is the same discussion the content creators have had here especially since Genesis.
Although sixus1 has been slightly more transparent in how he’s making his decision and has listened to peoples concerns and comments, which is refreshing in itself
As to the Original topic, does Behemoth 2 use geometry swapping as this was a know issue in early versions of DS4 and broke the morphs. The morph issue was corrected in later versions of ds 4 so the morphs should work in 4.5, although i’m not sure if the geometry swapping was fixed
I “bought” NightGaunt awhile back with a birthday coupon from Content Paradise (got him completely free with my coupon LoL) and he works fine in DS 4.5 Pro RC1. MATs really are not good in DS though, but the figure loads, morphs and poses just fine, if that helps anybody I don’t have any other Sixus1 figures though, sorry.
I’m downloading it now to have a look at, but if it’s geometry switching, then you need to know that DS has never been very good at dealing with it, and it was completely broken in 4.0.
EDIT
Yep, problems the geometry switching, and while the devs did “fix” it in 4.5 RC1 it looks like they broke it again in the full release of 4.5
EDIT
See my post above, it works fine for me in 4.5.0.114, or is that not what you mean?
When it comes to Geometry Switching in DS it’s a case of “what’s it doing” and “do we really need it”, in the case of Behemoth2 it’s to hide his genitals and no we don’t need it. The genitals have their own bone, which means we can click on the eye next to the bone in the scene tab and remove them from the scene, this stops them showing in the render as well as poking through any clothing.
So the easiest remedy is to remove the Geometry Switching references from the CR2, *points at pic* that’s him “fixed” with his Thicker FBM set to 1.
You might want to add to this bug report: https://bugs.daz3d.com/view.php?id=45887
I don’t have many non-DAZ figures installed at the moment, so I’ve only tested with Michael 2, who does work in 4.5.0.114
