Digital Art Zone
Is there any fracture plugin for Carrara?
Posted: 19 August 2012 02:10 AM   [ Ignore ]
New Member
Joined  2005-09-19
Carrara’s explode deformer don’t have any thickness option.
It’s ONLY flat…
the video link below is made with xplode plugin for Cinema4D.
http://xplode.valkaari.com/video.html
How to make this effect scene in Carrara?
Is it impossible to make in simple steps?
I asked the question about it two years ago but I don’t find out an answer until now.
Profile
Posted: 19 August 2012 05:26 AM   [ Ignore ]   [ # 1 ]
New Member
Joined  0
mukie,
    No there is’nt at this time but i sure as hell would like to see one…......CALLING ALL PLUG-IN DEVELOPERS ! ! !
Profile
Posted: 21 August 2012 07:49 AM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2007-07-13
You could use the Explode modifier instead.
 Signature
- Live Long and Prosper -
Profile
Posted: 21 August 2012 10:40 AM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
mmmm you could do an explode,
save file
export it as it starts to break up as an obj
reimport it, add thickness in the vertex room
run a physics sim
convert to keyframes shift it all to the point you exported the explode along the timeline
merge the original scene
untick visibility on the keyframed physics sim thickness added exploded obj
at the at the point of fracture untick visibility on the exploding object and tick viibility on the keyframed physics sim one
confused?
yep
I am,
and too cold to get out of bed and try it!
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 07 December 2012 03:55 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  0
Lightwave just added this feature - it’s very cool!
Image Attachments
Profile
Posted: 08 December 2012 02:55 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2011-01-03
dbuchter - 07 December 2012 03:55 PM
Yep…it was one of the reasons that I bought LightWave. Still learning how to use it effectively; but I can hardly wait to play with some fracture/Bullet animations.
 Signature
- Garstor
Australian-Canadian currently trapped in Texas (maintaining sanity with doses of Carrara, LightWave and PhotoShop)
My 3D art Flickr page for final or near-final images
My 3D art Flickr page for work-in-progress or experiments
Profile
Posted: 09 December 2012 06:38 AM   [ Ignore ]   [ # 6 ]
Active Member
RankRank
Joined  2012-04-01
The descrption of Pycloid has a few words that sounds like what you want., but the example animations try to show another effect, erosion.
I have no Pycloid skills yet, not sure if it does what you want:
PyCloid is an enhanced particle emitter. Two modes : - standard mode : particle emission from a point or an object surface - deformer mode : the facets of a mesh are converted to particles to simulate object destruction
Emission can be controlled by a shader to have variable particle density over the surface or achieve partial mesh destruction.
http://www.f1oat.org/pycloid/index.html
 Signature
Everything about Carrara: http://www.carraracafe.com/
Profile
Posted: 09 December 2012 06:50 AM   [ Ignore ]   [ # 7 ]
Active Member
RankRank
Joined  2012-04-01
The not so fast way to do it:
http://www.youtube.com/watch?v=-XGRj4VjPqk
 Signature
Profile
