Digital Art Zone
1 of 7
1
Plugin version numbers for DS 4.6
Posted: 18 August 2012 12:56 PM   [ Ignore ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Updates May 16
Items which have not been updated should still work in DS4.6
Thanks to Jay Nola for providing this list.
These have been updated for 4.6
Genesis Starter Essentials (1.13)
3D Bridge for Photoshop (1.3.0.8)
GoZ for DAZ Studio (1.3.0.8)
Decimator for DAZ Studio 4.5+ (1.4.0.18)
DSON Importer for Poser (1.1.0.18)
Dynamic Clothing Control (1.3.0.18)
Mimic Live! (1.3.0.18)
Elite Human Surface Expansion Pack 1 (1.1)
omAreaLight Light Shader for DAZ Studio (1.3)
pwCatch (1.2)
pwEffect (1.2)
pwGhost (1.2)
pwSurface 2 (1.2)
pwToon (1.2)
pw Shaders Bundle (1.2)
UberEnvironment Light Shader IBL/HDRI (1.3) (no update needed from June version)
UberEnvironment HDRI Pack 1 (1.1 for DS4 / 1.1 for DS 2 & 3)
UberHair Shader Upgrade for UberSurface (1.3) (no update needed from June version)
Uber Lighting Bundle (see each item in the bundle for the current version)
UberPoint Light Shader for DAZ Studio (1.3)
UberSoft Lighting Kit (1.3)
UberSpot Light Shader for DAZ Studio (1.3)
UberSurface2 Layered Shader for DAZ Studio (1.3)
Genesis Generation X (1.2)
GenX AddOns for Gen 3 (1.2)
re PoseMaster, cridgit says:
I can confirm PoseMaster works in 4.5 but I have noticed not all the tests pass. This is due to something having changed in how DS handles node scaling but it won’t affect 99% of your pose transfers. I’m still investigating the root cause and will possibly be releasing an update if deemed necessary.
Faceshop is now at version 8EZ.  FaceShop tutorial videos and current versions of FaceShop can be downloaded from:
http://www.abalonellc.com
If you have FaceShop 7+ Abalone LLC has a new plugin (dll) that works with the release version of DAZ Studio 4.5 and not the RC versions.
It is are out for 32-bit and 64-bit for PC and the Mac version is in the works. according to Abalone LLC.
To use replace the existing faceshoploader.dll in the Studio “plugin” folder.
They can be downloaded at this link.
http://www.abalonellc.com/free-upgrade-for-existing-pro-users.html
Alessandro_AM has updated INFINITO 1.1 to work with 4.5.  The new versions can be downloaded at:
http://www.alessandromastronardi.com/INFINITO1.1_4.5/infinitoPlugin.OSX.32.zip
http://www.alessandromastronardi.com/INFINITO1.1_4.5/infinitoPlugin.OSX.64.zip
http://www.alessandromastronardi.com/INFINITO1.1_4.5/infinitoPlugin.WIN.32.zip
http://www.alessandromastronardi.com/INFINITO1.1_4.5/infinitoPlugin.WIN.64.zip
You do not install Darkside with 4.5, it is built in.
If you have multiple copies of DAZ Studio and want to have the Photoshop Bridge work for both you need to install one version to the Adobe Plugins folder and the other to your Alternate plugins folder that you set in preferences in Photoshop or Photoshop Elements.  You can’t put both versions in the same plugins folder.
Other updated plugins are in the works and will be released by venders when they are done and many have announced that they are working on them now.
Please report any updates to items on this list and things I don’t have on it.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 19 August 2012 01:02 PM   [ Ignore ]   [ # 1 ]
Active Member
RankRank
Joined  2010-11-30
Part 2 Last Updated 5-16-2013.
Dimension3D has released 1.2 versions of these products for DS 4.5.
GenX AddOn Gen3 Bundle
GenX AddOn Gen3 for A3 and H3
GenX AddOn Gen3 for S3 D3 and F3
GenX AddOn Gen3 for V3 and M3
Genesis Generation X (Upgrade from Gen4)
Uninstall your older version and reset your downloads to get the newest version of them.
Dimension 3D posted this information in another thread about the above mentioned updates.
Besides working in DS 4.5, there are also some improvements and bug fixes in the new version.
1. The morphs are now transferred with an improved scheme to get smoother results in particular for the face (s. image). The improved presets are selected initially by default when loading a figure in GenX. The former presets are still included, they are marked by [1.0] just in case you prefer the old scheme.
2. It happened sometimes that a few single points were transferred wrong, in some cases this ruined the transferred morph, in other cases it was hardly visible. This bug has been fixed, there should be no more errors in the transferred morphs.
3. It is now possible to get morph values (i.e. dial settings) directly from a figure in the DS scene. If you have a character saved in a DS scene or as a DS script, or if you have otherwise problems to load the morph values into GenX, you can now load or setup the figure in the scene and get these values from there.
4. GenX now supports compressed DSF files and has some other adjustments to be compliant with the DS 4.5 file format.
Because of 1. and 2., I recommend to transfer your morphs again to get better results.
Because of 1., you should also update the Gen3 add-ons to benefit from the improved morph transfer. (Edited to add: In particular the Gen3 add-ons for A3 and H3 have been improved to work better in the eye area, e.g. the morph for closing the eyes transfers much better now.)
DSF Toolbox has been updated to version 1.1 to work with DS 4.5.
Instaling/Updating INFINITO 1.1.0.1 Instructions.
The installers for INFINITO and DS 4.5 are available now.
If you have INFINITIO 1.1.0.1 installed already for DS 4 in the folder and you installed DS 4.5 you can do this instead of having to uninstall it and run the newer DS 4.5 installer.
1.) Download the updated plug in file for you version of DS 4.5 from the links in the 1st post.
2.) Replace the older infinito plugin file in your plugins folder of DAZ Studio with the newer one. Note: The name on the older one may not be exactly the same as the newer one.
Reality has now been updated to version 2.5 so it will work with DS 4.5
You need the latest version of Lux Render(10.0 or higher) for it to work.
You can download the updated plugin and get the newest version of Lux Render by going to these links.
http://preta3d.com/tasks/Reality2Download.php
http://www.luxrender.net/en_GB/download
NyaNyan posted this information on what needs to be done to make the Mirei Anime and Toon Style Shader for DAZ Studio 4 work with 4.5
For DS4.5
please download shader files and replace them.
1. download   http://www.geocities.jp/nyankko15/DAZStudio/mirei/mirei_shader_files_for_DS45.zip
2. extract zip file
3. replace shader files
    DAZ Studio 4\shaders\Nyanyan\mirei\mirei_surface.sdl
    DAZ Studio 4\shaders\Nyanyan\mirei\mirei_displacement.sdl
These shader files are simply re-compiled with DAZ Studio4.5.
Manga Style & Visual Style Shaders work in DS 4.5.
The current versions for them are:
Manga Style Shaders (1.1)
Visual Style Shaders (1.2)
The Documentation for Manga Style Shaders can be gotten at this link.
https://dl.dropbox.com/u/12960659/Daz3DWork/Documentation/MangaStyle_Documentation.pdf
The Documentation for Visual Style Shaders can be gotten at this link.
https://dl.dropbox.com/u/12960659/Daz3DWork/Documentation/VisualStyle_Documentation.pdf
A Step by Guide On How To Apply The Manga Preset Shaders To Genesis can be gotten at this link?
https://dl.dropboxusercontent.com/u/12960659/Daz3DWork/Documentation/VisualStyle_StepByStep.pdf
A Step by Guide On How To Apply The Manga Preset Shaders To Genesis can be gotten at this link:
https://dl.dropbox.com/u/12960659/Daz3DWork/Documentation/MangaStyle_StepByStep.pdf
A Freebie Pack for Manga Style Shaders can be gotten at this link.
https://dl.dropbox.com/u/12960659/Daz3DWork/Freebies/BishyT_MangaStyle_FreebiePack1.zip
A Free Geometry Shell Outline shader can be gotten ar this link.  (Note: This shader was update May 19th, 2013 to fix a bug.)
https://dl.dropboxusercontent.com/u/12960659/Daz3DWork/Freebies/BishyT_GeoShellOutline_FreebieShader.zip
The official thread for the Manga Style Shaders & Visual Style Shaders is at:
http://www.daz3d.com/forums/viewthread/10961/
PoseMaster for DAZ Studio PoseMaster has been updated for DS 4.5. The new version uses the DUF format which prevents the annoying dialog popup during batch conversion (plus a few other improvements).
The current version numbers for PoseMaster for DAZ Studio and PoseMaster People Pack are:
PoseMaster for DAZ Studio PoseMaster (1.5)
PoseMaster People Pack (1.0)
Luxus
The current version is:
Content (1.0.0.2)
Plugin (1.0.0.5)
graphMate
Current version is (1.0.0.0).
keyMate
Current version is (1.0.0.5).
Garibaldi Express Hair System For DAZ Studio
Plugin (1.0)
Documentation and Freebies for it are at:
http://www.garibaldiexpress.com/downloads.html
Look At My Hair & Look at my Hair FREE Player
Look At My Hair (1.0.0.0)
Look At My Hair Player (1.0.5.0)
Official website with free presets, documentation, news, & video tutorials is at:
http://www.furrythings.com/
Sickle Rigging and Morphing System
Current version is (1.2).
These Shaders have been reported to be working in DS 4.5 without problems on the forums.
Gemologica
Silkessence
The Fabricator
Therese Shaders are for DS 4.6
Subsurface Gummy & Plastic Shaders (1.0)
Subsurface Shader Base (1.0)
Subsurface Toon Shaders (1.0)
Note: Subsurface Shader Base are free and was added to Product Libraries for existing DS users.  They are part of DS 4.6.
Profile
Posted: 19 August 2012 02:38 PM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Thanks for the info.  Got this bookmarked to keep tabs…. Got all my PWSurface shaders and Uber - OM and waiting on Elite…. Wish to the GODDESS they would buy PWSketch PoseWorks…. such a nice plugin!  Oh well.!
 Signature
—-Wolff On The Prowl—-
Posts: 28,985 and counting!
        RAMWolffsWorld
Profile
Posted: 19 August 2012 02:49 PM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-25
Thank you SO MUCH for starting this thread!
RAMWolff - 19 August 2012 02:38 PM
I agree with the sentiment, but I believe at the time we were told that pwSketch contained additional technology that wasn’t Poseworks’ to sell. :(
I’m almost done teaching stats for the summer, and then I’ll get back to work on my sketch shaders. :)
Profile
Posted: 19 August 2012 03:07 PM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
If you and BishounenTaurus can get some really good sketch shaders created it would be really awesome.  I’m such a crosshatching fan.  He was getting some good results for sure but I’ll get both sets if they have good ideas packed in.
 Signature
        RAMWolffsWorld
Profile
Posted: 19 August 2012 04:29 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2011-03-26
Thank you for this list.
Allthough there is still some confusion left:
Was the Uber Shader Pack also updated?
http://www.daz3d.com/shop/uber-shader-pack
The “Uber Shader Pack” contains some more shaders than the “Uber Lighting Bundle”.
In the “Uber Lighting Bundle” are included:
•UberEnvironment Light Shader IBL/HDRI
•UberEnvironment HDRI Pack 1
◦(not sold separately - only available in this bundle and in DAZ Studio 3 Advanced)
•omAreaLight Light Shader for DAZ Studio
•UberSpot Light Shader for DAZ Studio
•UberPoint Light Shader for DAZ Studio
In the “Uber Shader Pack” are included:
◦UberSpot
◦UberPoint
◦omAreaLight
◦UberEnvironment
◦UberSurface2
◦UberHair
◦UberSoft Lighting kit
◦UberSoft Light Pack1
◦Elite Human Surface Expansion pack1
What did I do?
I reset the “Ueber Shader Pack” in my download history.
I got a lot of different versions for mac and pc, and for ds2, ds3 and ds4 in My Downloadable Products.
Most of them seem to be the version 1.3.
What is confusing?
What confuses me though is that there are no files that are explictely named version 4.5
I do not want to mess up a freshly installed DAZStudio_4.5.0.114_Win64 by overwriting some shaders with maybe older version that were intended for DS4.0.3 only.
For example by reseting my downloads on the Dynamic clothing control I got installers that were clearly named for which version they are intended:
Dynamic Clothing Control for DAZ Studio 4.5.x 64-bit - exe - pc
Dynamic Clothing Control for DAZ Studio 4.0.3.x 64-bit - exe - pc
This is not the case for the Uber Shader Bundle were the installers are named:
Uber Shader Pack - 10973_UberSoftLightingKitDS3_1.3_ds.exe - pc
Uber Shader Pack - 10973_UberSoftLightingKitDS4_1.3_ds.exe - pc
Those installers seem to have no distinction between 4.5 and 4.0.3.
Can a representative of DAZ explain if the shaders named DS4 I got by reseting the “Uber Shader Pack” are intended to be used with DAZStudio_4.5.0.114_Win64?
 Signature
My facebook page is always updated first with Computer Graphics, Photo and Video projects.
On deviantArt I post Computer Graphics and Photo projects.
On youtube you will find my Video projects.
Profile
Posted: 19 August 2012 04:54 PM   [ Ignore ]   [ # 6 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
The first post gives the versions for most of those that work with DS4.5, most are version 1.3
 Signature
Products In Zips
Profile
Posted: 19 August 2012 05:27 PM   [ Ignore ]   [ # 7 ]
Active Member
RankRank
Joined  2010-11-30
The ones marked 4 are for 4.5 and 4.0.3.  Most of the 1.3 ones were at 1.2 until just recently.
During the testing of 4.5 it was reported that UberSurface2 wasn’t working and those shaders and others got updated after that was reported.
Also, not all the shaders that Daz sells in its store are going to be updated or need to for 4.5.  If they are working fine now they won’t be.  The older Elite Human Surface Shader for example wasn’t updated for Daz Studio 4 and may not be for 4.5 unless it is reported that it doesn’t work right..
Profile
Posted: 20 August 2012 08:44 AM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2005-09-19
I’ve just been checking my plugin status and I’ve got a red plug against ‘dzautoriggercontrol’ - I’m not even sure which product that is associated with, help anyone?
Profile
Posted: 20 August 2012 08:55 AM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2011-03-26
DWG - 20 August 2012 08:44 AM
I noticed that too. The ones I also had at red status were “Dynamic Clothing Control” and “Dezimator”.
After updating both the “DZautotriggercontrol” was now also back to green.
My guess is that “DZautoriggercontrol” is included in one of them as well and updated by updating one of them.
If i had to bet I would set my money that “DZautoriggercontrol” is linked to “Dynamic Clothing Control” because in that process there seems to be some kind of rigging involved. Maybe someone else can tell for sure.
The Dezimator installer you should get when you reset your DS4 downloads.
The Dynamic Clothing Control installer you get when you reset your Dynamic Clothing Control downloads.
@fixmypcmike and jay_nola: Thx for clearing the 4.0.3 and 4.5 compatibility up.
 Signature
Profile
Posted: 20 August 2012 09:41 AM   [ Ignore ]   [ # 10 ]
Active Member
Avatar
RankRank
Joined  2005-09-19
Thanks Linvanchene, I’ve just reset Dynamic Clothing Control, so that may take care of the autorigger issue.
Am I right in thinking Decimator is the plugin you only have a valid serial number for if you actually bought the full price DS4 Pro?
Profile
Posted: 20 August 2012 09:47 AM   [ Ignore ]   [ # 11 ]
Active Member
Avatar
RankRank
Joined  2011-03-26
DWG - 20 August 2012 09:41 AM
As far as I can remember that is the case.
I did buy the DS4 pro upgrade sometimes in 2011 and the decimator plugin is functional.
You can still buy the standalone version of the Decimator for DAZ Studio to get a serial number:
http://www.daz3d.com/shop/decimator-for-daz-studio
 Signature
Profile
Posted: 20 August 2012 10:16 AM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2005-09-19
linvanchene - 20 August 2012 09:47 AM
I think I’ll pass at that price wink Thanks!
Profile
Posted: 20 August 2012 02:01 PM   [ Ignore ]   [ # 13 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-25
DWG - 20 August 2012 10:16 AM
Me too, unless they discount it further during the PC Anniversary sale, assuming there is one in October this year.
 Signature
OK . . . Where’s my chocolate?     Post Count —> 3,263 and growing!     Visit my Renderosity Gallery
It’s what you learn after you know it all that counts ~ John Wooden
Profile
Posted: 20 August 2012 07:18 PM   [ Ignore ]   [ # 14 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Yes, DzAutorigger is part of Dynamic Clothing Control.  If you never had the paid control, the basic one gets updated when you install 4.5, but if you had the advanced control you need to reset that to reinstall it.
Decimator is the plugin that is included if you paid for DS4Pro, but not in the free one.
 Signature
Products In Zips
Profile
Posted: 21 August 2012 01:53 PM   [ Ignore ]   [ # 15 ]
Active Member
RankRank
Joined  2010-11-30
Moved and edited into the second post in this thread.
Profile
1 of 7
1
