Digital Art Zone
Area Light with Shader Mixer
Posted: 18 August 2012 07:47 AM   [ Ignore ]
New Member
Joined  2012-02-19
Hello,
I turned a simple plane with the shader mixer into an area light. That works. The plane emits light. But I still see the plane itself in the rendered image. Turn off the option “visible in Renderer” turn also off the light.
How can I make the plane invisible but still have the light?
Thanks for your help.
Profile
Posted: 18 August 2012 08:19 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
What happens if you set Opacity to 0? Failing that you could use a RayIs brick to make it selectively transparent via an If brick.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 18 August 2012 08:44 AM   [ Ignore ]   [ # 2 ]
New Member
Joined  2012-02-19
That works, thanks a lot.
In my first attempt I deleted the DAZ Default Material with the opacity property from my shader . But its still needed for exactly that reason.
Profile
Posted: 18 August 2012 09:06 AM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Oi on the root brick is Opacity - you can just give it a constant value.
 Signature
Profile
