More2burn - 02 March 2013 06:38 AM
Thanks for the response. I changed the path and got SOME things. Genesis wasn’t one of them so I just downloaded the installer the old fashioned way and tried that method and made sure the path was the same but this didn’t work either. Genesis still isn’t there :(
I had the same issue. Here’s how I fixed it:
Change the default path of the DIM installer, which it seems you’ve already done.
Next, change to the Content Tab in DS, bring up its menu and. Select DB Maintenance. Check Reset Database.
Once you do that, bring up the DB Maintenance menu again, and select every other option EXCEPT Reset Database
Finally, go into the DS Preferences, select the Startup Tab, and uncheck Load Default Scene. Older versions of DS had this checked by default and it would load a blank Genesis figure, this scene/.dsf file is no longer there in DS 4.5, but the Preference is a carry over from earlier versions.
Restart DS.
You may have to go thru the DB Maintenance process a second time to straighten it all out, but this finally fixed everything for me.
Also, I assume you have DIM managing your installs now and have already gone thru the process of uninstalling your previous content using the uninstallers in the Uninstallers folder in your My Library folder before re-installing your content using the DIM.
-Patrick
