I’m getting off to a slow start with this. Got a couple of issues.
1. I’ve seen someone post a preview of the Aged morph for M4. So I know that it *will* transfer. I can drag the Aged morph into the field for transfers. But it comes in at zero value, so it won’t transfer, since I gather that only morphs set at something other than zero value are transferable (I get an alert box that says there isn’t anything to transfer, even when I’ve checked the boxes in the list). The column which shows the value is not a live text column, I cannot change the value in the column to something other than zero. How do you activate the morph so that it will transfer? I am assuming that I have to drag it in from somewhere else, like the parameters tab after applying it to a figure. Or is this when you choose some other option in the select drop-down?
2. This is related, but at a remove. I have a lot of character targets that I would like to transfer, but they do not apply automatically. You can’t just click on them. I always have to point the program at a subfolder in the library/morphs folder, or some such thing, usually more than once, before the character will apply. Ergo, these cannot be drag-and-dropped into the transfer field, because the links to the actual morphs do not come in by dragging. I can apply them to the base figure that they are intended for, but how do I move them from an actual figure rather than the content list. I gather that this can be done, since how else would someone transfer in an older figure that they dialed from an earlier base figure?
3. As you may guess, I’ve got some dud transfers that show up in my list of GenX transfers, where the body transfered, but the head didn’t, or transfers where the transfer was fine, but I somehow managed to direct the plugin to the wrong .png to identify it. How do you edit or delete your previous transfer files?
