Digital Art Zone
Casting shadows without the object being visible
Posted: 16 August 2012 03:58 AM   [ Ignore ]
Member
Rank
Joined  0
Hi,
I need my object to cast shadows, but I don’t want it to appear in the rendered picture (as if it was completely transparent).
Can this be done?
Thanks.
Profile
Posted: 16 August 2012 04:20 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
Not sure
but Fenrik has a “toward/away’ shader with which you can have different shaders on either side of a polygon. I guess you could make one side transparent?
Put it in the alpha chanel and then invert.
Maybe not,
http://www.daz3d.com/shop/pose-and-shading-tools-2
Also Inagoni has baker which will bake shadows onto a texture and let you export it - so the shadow will still be there even if object casting said shadow is not.
http://www.inagoni.com/e107_plugins/content/content.php?content.3
you can also put texture maps on lights
so with some fiddling you could get the shadow on the texture map and project it
also carrara has negative lights which with fiddling could emulate a shadow
just depends what its the shadow of I guess
 Signature
http://andrewfinnie.blogspot.com.au/
Profile
Posted: 16 August 2012 04:57 AM   [ Ignore ]   [ # 2 ]
Active Member
RankRank
Joined  2007-10-15
I think maybe you’re talking about a shadow catcher?
Maybe if you describe a bit more what you’re trying to do…cause it’s not real clear what result you want to get. You can remove objects from your render in post (using an “object index” pass), leaving only their shadows, but I’m guessing that might not be what you really want.
Profile
Posted: 16 August 2012 05:41 AM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2005-04-12
If you are using a distant light, you could just move the object out of the field of view, and the shadow will stay the same size.
But as has been said, you perhaps need to describe what you want to achieve in more detail, including what lighting you have in your scene.
Profile
Posted: 16 August 2012 05:55 AM   [ Ignore ]   [ # 4 ]
New Member
Avatar
Joined  2008-10-13
Hello Eyos!
That´s an easy one:
Just apply a black color / 0% to the Alpha-Channel to your “ghost”-object and
put off “Light through Transparency” in the Rendering-Room-Tab.
Voilá!
Greetings
tezen
 Signature
www.zen3.de
Profile
Posted: 16 August 2012 05:59 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2008-01-28
Heh, heh
Live and learn eh? Nice idea tezen
 Signature
Profile
Posted: 16 August 2012 06:07 AM   [ Ignore ]   [ # 6 ]
New Member
Avatar
Joined  2008-10-13
Hey Headwax!
Live&Learn;? Sometimes… but mainly I`m waiting for earned money. Until that I`ll relax :D !
Greetings tezen
 Signature
www.zen3.de
Profile
Posted: 16 August 2012 06:36 AM   [ Ignore ]   [ # 7 ]
Member
Rank
Joined  2005-04-12
tezen - 16 August 2012 05:55 AM
Hello Eyos!
That´s an easy one:
Voilá!
Greetings
tezen
OK provided there is no other transparency in your scene.
Profile
Posted: 16 August 2012 07:00 AM   [ Ignore ]   [ # 8 ]
New Member
Avatar
Joined  2008-10-13
@PhilW: Of course! ...but with some compositing-work even that is possible.
 Signature
www.zen3.de
Profile
Posted: 16 August 2012 08:06 AM   [ Ignore ]   [ # 9 ]
Member
Rank
Joined  2005-04-12
Very true!
Profile
Posted: 16 August 2012 11:16 AM   [ Ignore ]   [ # 10 ]
Member
Rank
Joined  0
I appreciate all the ideas and suggestions. Thank you very much everybody.
Eyos
Profile
Posted: 16 August 2012 05:32 PM   [ Ignore ]   [ # 11 ]
Active Member
RankRank
Joined  2007-10-15
tezen - 16 August 2012 07:00 AM
ANYTHING is possible with some compositing work, but “fixing it in post” shouldn’t be the goal. I’m still curious about the original intent. Something isn’t quite adding up. I just hope he’s not going roundabout for something he doesn’t need to go roundabout on.
Profile
Posted: 16 August 2012 08:28 PM   [ Ignore ]   [ # 12 ]
Power Member
Avatar
RankRankRank
Joined  2006-08-27
JoeMamma2000 - 16 August 2012 04:57 AM
I agree, more information about the scene would help.  I was thinking a shadow catcher as well, but they can also act as a mask. If there’s an object in the scene that’s behind it, or partially obscured by it, then it would be masked by it. Strangely, I used one once and mistakenly intersected the shadow catcher with a model (I was using it to mask the model I wanted it to appear later in an animation), and the model behind it was completely visible. Of course the alphas in the shader on the object may have confused Carrara as well.
Profile
