Digital Art Zone
Help with fitting hose in DS please:)
Posted: 15 August 2012 10:47 PM   [ Ignore ]
Member
Rank
Joined  2005-09-22
Ok I’m working on a render that has V4 in it & she is standing with 1 leg bent & propped on a chair.How can I get the hose to fit her properly. I did it in a render long time ago & can’t remember how I got the hose to fit right.Is there a secret to DS & hose lol?
thankies much
Rose
 Signature
May the hands of fate be kind to you & yours. smile
Profile
Posted: 16 August 2012 06:04 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
How badly is it not fitting? If it’s not following the pose at all you need to fit it to the figure, assuming it’s made for the figure you are using and is itself a figure and not a dynamic prop. Minor bulges may have adjustment morphs in the tights to fix them.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 16 August 2012 10:42 AM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2005-09-22
Richard I moved it from DS3 to DS4.5 so I can try out the transfer active morphs.I’ve got most the hose to fit except at the left ankle.Here is a render of the area i have left.The lighting isn’t great-haven’t fixed it yet lol.i was wondering if that little bit can be done with magnets & if there is a tut for using ds4 magnets?
Image Attachments
 Signature
Profile
Posted: 16 August 2012 12:37 PM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Ugh, yes. Is this on the figure it was made for, not autofitted to Genesis? Have you tried adding a smoothing modifier to the tights, with collision detection on?
 Signature
Profile
Posted: 16 August 2012 02:00 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2005-09-22
i ran the smoothing modifier but it didn’t let me set collision detection. so i bet that was my prob.actually i don’t even think it opened anything for me to set that.-was my first time trying that step.the hose is on v4 with a character morph used.it’s meant for v4,a4, or g4 or a mix i think
 Signature
Profile
Posted: 16 August 2012 02:12 PM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2005-09-22
i got this result when i ran the smoothing modifier.
Image Attachments
 Signature
Profile
Posted: 16 August 2012 03:43 PM   [ Ignore ]   [ # 6 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
There’s certainly something very odd there, either in the clothing or in the pose of the figure (and that looks OK at a glance). Which item is this?
 Signature
Profile
Posted: 16 August 2012 03:57 PM   [ Ignore ]   [ # 7 ]
Member
Rank
Joined  2005-09-22
this 1 -Hypnotic Lingerie(link edited out due to not viewable )  but i always have issues with hose-no matter what type or which version of DS. I’m just cursed with it:) I just updated my DS to the newest release so may re-try the smoothing modifier.
 Signature
Profile
Posted: 16 August 2012 04:06 PM   [ Ignore ]   [ # 8 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Your link goes to a “not currently available for viewing” page for me, but I have a limited range of lingerie and I don’t think any sets of stocking or tights from Renderoisty, so I probably can’t test it myself.
 Signature
Profile
Posted: 16 August 2012 04:19 PM   [ Ignore ]   [ # 9 ]
Member
Rank
Joined  2005-09-22
oh I forgot -it was a sneak peak item from yesterday it’s the Hypnotic Lingerie set. Sorry bout that. I had no issues with anything else. & I think the leg part & foot part is almost adjustable separately-think that’s why it bunched at ankle.
 Signature
Profile
Posted: 16 August 2012 04:31 PM   [ Ignore ]   [ # 10 ]
Member
Rank
Joined  2005-09-22
at what point of apply smoothing modifier is it supposed to let you set it for collision detection? I had to re-add the hose because some reason my saved file didn’t have the hose in it. & even after updating-I get same results.
 Signature
Profile
Posted: 17 August 2012 08:13 AM   [ Ignore ]   [ # 11 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
You set the Collision target and so on in the Parameters pane after applying the modifier.
 Signature
Profile
Posted: 17 August 2012 10:51 AM   [ Ignore ]   [ # 12 ]
Active Member
RankRank
Joined  2012-02-04
Studio 4 should also automatically set the collision item to the figure the stockings were ‘Fit’ to, so you usually don’t have to change that setting.  What often needs tweaking is the number of collision iterations and smoothing iterations.  Smoothing of generation 4 clothing I find often works best with the iterations dropped to between two to five, much lower than the default 20.  Collision iterations I find need much less tweaking.
I use the BO SuperHose from Renderosity most of the time when I need stockings on a generation 4 figure.  They have a fair few adjustment morphs in them for the different sections.  E.g., AdjustThigh, AdjustShin, AdjustHeel, etc.  My usual approach is to shrink them to around 99% scale after fitting them to a figure.  I then further tweak the adjustment morphs, particularly the thighs, to have the stockings just dip under the skin of the figure.  Then use smoothing and collision and you get a super-tight fit.  (I can’t stand renders where the hosiery is floating away from the legs; it just looks horrid.)
A couple examples of this technique with the BO SuperHose (both NSFW): Simple Nude 001 and Couch Sirens (the girl in red, the other is using the dynamic clothing stockings from Optitex’s Santa’s Helper outfit).
 Signature
My deviantART Homepage
Profile
Posted: 17 August 2012 09:41 PM   [ Ignore ]   [ # 13 ]
Member
Rank
Joined  2005-09-22
thank you both sooooo much.i’ve been dying for a way to get hose in ds to fit good—-i think i may finally be able too.i owe ya both big hugs. i found those adjustments in the parameter tab & fixed the horrid bunching & most of the pokies.i’ll still have hopefully very slight postwork but not as much lol.when i get this done-i’ll try to get a link posted:)
edit—-
here it is finished : http://www.renderosity.com/mod/gallery/index.php?image_id=2359044  again thankies very much for the help.
 Signature
Profile
Posted: 22 August 2012 12:08 PM   [ Ignore ]   [ # 14 ]
Member
Rank
Joined  2009-03-29
I saw you’re topic a few days ago and was having the same problem. In the mean time i solved it in a different way as mentioned in this thread, that i wanted to share (DAZ version 4.5).
Tested it with superhose and several other stocking products
-Conform the superhose on to Genesis.
-From autofit select V4 and the Pants (Thight) option.
-Do not use the Smooth modifier
-Select the superhose in the scene menu
-Right click on the scene tab
-Select the “Assets -> Transfer utility” from the menu
-Source: Genesis from the drop down menu scene item
-Target: (super) hose from the drop down menu scene item
-Accept and enjoy grin
Now the superhose is a lot better fitted and also will follow genesis when shaping her/him
EDIT: By accident typed the boots option for autofit, this should be the pants tight option. If you chose the boots option with the superhose, the hip will be not follow the shapes correct. Other stocking product (with no hip work also work with the boot option correct)
Image Attachments
Profile
