Digital Art Zone
1 of 4
1
flame settings problem
Posted: 15 August 2012 12:03 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2010-03-15
I am using a flame plane that looks awesome ... until I render. When I render it gets too bright and blurred. How can I keep it looking more like how it look in the DS3 interface?
Image Attachments
 Signature
*Clinging to DS3 for dear life*
Aidana WillowRaven
http://WillowRaven.weebly.com
I ask for so little. Just fear me, love me, do as I say and I will be your slave.
Profile
Posted: 15 August 2012 12:06 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Can you post the settings from the Surface tab?  Odds are it’s either Ambient strength or Specular Strength.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 15 August 2012 06:00 AM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
DS3 Intereface, well as close as can be, can be done through playing about in the Workspace and Layout editor located under Window (top menu bar). From memory I think the Workspace set to Self Service should give you a close DS3 IU. Choose whatever Layout you like the look of.
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Profile
Posted: 15 August 2012 07:23 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Szark - 15 August 2012 06:00 AM
Umm, I don’t think the OP is asking how to make DS4 look like DS3, but rather how to make the flame in his render look like the flame in the preview, and he’s USING DS3.
And, OP, like was said above, I’d lay odds it’s the specular highlight on your flame prop that is making it so bright.
 Signature
A good pun is its own reword
“The greatest sin is to be unteachable” - Dr. Pat Allen
Profile
Posted: 15 August 2012 07:35 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
Right. I am using DS3. I am trying to adjust the settings so my flame after render looks more like the flame looks in the interface.
I tried setting both spec settings to 0, but no noticeable change, so I put them back so ya’ll can see them at their original settings.
Image Attachments
 Signature
Aidana WillowRaven
Profile
Posted: 15 August 2012 07:40 AM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Sorry my bad I just misunderstood the question. I will go away and hide somewhere.
 Signature
Pete
My Render Thread
Profile
Posted: 15 August 2012 07:41 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2005-10-26
Have you tried adjusting the ambient setting?  Try plugging the diffuse texture into the ambient channel and set the color to white.
Edit: oops, I missed the first couple of posts somehow, but the ambient setting is a bit high, maybe lower the strength.
 Signature
Old post count 4147
MY DA Gallery : http://flashback37.deviantart.com/
Profile
Posted: 15 August 2012 07:41 AM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
Szark - 15 August 2012 07:40 AM
No need to hide ... lol. Any ideas?
 Signature
Aidana WillowRaven
Profile
Posted: 15 August 2012 08:06 AM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
flashback - 15 August 2012 07:41 AM
I have set everything to zero, with still no effect. spec glossiness and strength both o and color white, ambient to zero color white. ... I about to say screw it and use a png in post ... lol.
 Signature
Aidana WillowRaven
Profile
Posted: 15 August 2012 08:15 AM   [ Ignore ]   [ # 9 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
AidanaWillowRaven - 15 August 2012 07:41 AM
LOL Yes can you post a screen cap of all the surface channels of the flame please? I can hardly read your first image and it only shows a portion of the channels. But from what I can see that looks ok. But to make sure set Spec and gloss to 0%. Make sure reflection and refraction are set to 0%.
I would definitly give what flashback suggested a try. In fact I do that for all flames.
 Signature
Pete
My Render Thread
Profile
Posted: 15 August 2012 08:17 AM   [ Ignore ]   [ # 10 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Sorry to slow in typing.
Ok if not the surfaces let’s look at your lighting….what shadows are you using? What is your “Max Ray Trace Depth” setting set at. (found in the Advanced Render Settings Pane)
 Signature
Pete
My Render Thread
Profile
Posted: 15 August 2012 08:35 AM   [ Ignore ]   [ # 11 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
Szark - 15 August 2012 08:17 AM
The MRTD is 16.
I am using the enchanted island light set 1 with raytraced shadows.
 Signature
Aidana WillowRaven
Profile
Posted: 15 August 2012 08:40 AM   [ Ignore ]   [ # 12 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Ok 16 is way to much for just about most renders. Try 1 and this will drive down your render times. Anyways that is not the issue.
The Light set I am not familair with. Try turning down your lighting or turn all lights off barring one a test render. Then turn anothr on and render.
Is this a home made prop?
 Signature
Pete
My Render Thread
Profile
Posted: 15 August 2012 09:11 AM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
Szark - 15 August 2012 08:40 AM
I think it was a freebee I grabbed somewhere. If I alter the lights, everything else gets dark. I think I will work with a png after all.
 Signature
Aidana WillowRaven
Profile
Posted: 15 August 2012 09:14 AM   [ Ignore ]   [ # 14 ]
Active Member
Avatar
RankRank
Joined  2010-03-25
what kind of flame pane you using?
 Signature
“When the power of love overcomes the love of power, then the world will know peace”  ~ Jimi Hendrix
My Daz & Poser animations http://www.youtube.com/user/IvySummers1
Profile
Posted: 15 August 2012 09:16 AM   [ Ignore ]   [ # 15 ]
Active Member
Avatar
RankRank
Joined  2010-03-15
Ivy Summers - 15 August 2012 09:14 AM
Kind? Just a flat plane with a flame on it ... lol.
 Signature
Aidana WillowRaven
Profile
1 of 4
1
