Digital Art Zone
behavior + physics
Posted: 14 August 2012 06:29 PM   [ Ignore ]
New Member
Joined  2005-09-12
Hello
Is it possible to combine behaviours and physics? I want to make a spinning coin that settles on a table.
So, I thought I might combine a modifier (behaviours > spin) with physics, but the behaviour only works with the keyframe method.
Any ideas?
Br, Donleavy
Profile
Posted: 14 August 2012 08:10 PM   [ Ignore ]   [ # 1 ]
Active Member
RankRank
Joined  2007-10-15
I think with physics there’s an option to set an initial velocity. In this case it’s an angular velocity, so set it at whatever you want to make it start out spinning. No need for keyframing or anything else. But you’ll have to set the Z axis angular velocity to a very high value, maybe 5000 or something.
Anybody fall asleep ?
Profile
Posted: 14 August 2012 08:16 PM   [ Ignore ]   [ # 2 ]
Power Member
Avatar
RankRankRank
Joined  0
Works on a simple cylinder primitive:
Image Attachments
 Signature
my tutorials etc—> www.3d.wetcircuit.com
Carrara animation showcase on YouTube .... search the old DAZ3D forums
*new* FREEPOSITORY at Carrara Cafe
Profile
Posted: 14 August 2012 10:00 PM   [ Ignore ]   [ # 3 ]
Active Member
RankRank
Joined  2007-10-15
I think you can also add a “torque force” to slow down the spin afterwards. Or maybe the “damping force”. I didn’t try either, but initial velocity seems to work fine.
http://youtu.be/yKLW3fLk5vE
Profile
Posted: 15 August 2012 01:26 AM   [ Ignore ]   [ # 4 ]
New Member
Avatar
Joined  2006-06-27
Works for me…thanks Holly http://youtu.be/cToExRucyqQ
0%
 Signature
“There is never enough sleep for the salior of the night” jcrabb
And as always:  “Educate don’t Humiliate
Profile
Posted: 15 August 2012 03:28 PM   [ Ignore ]   [ # 5 ]
New Member
Joined  2005-09-12
Thank you for your help - that did the trick! Now the trick needs tweaking to look convincing….
Profile
