This has probably been requested before, but I am looking for a way to create light sabers in DAZ 4.5 (M5/V5). I would love to try making some Star Wars type art!
“robkelk”, thx for replying but the file you gave me for the lights only contains a metal stand for ATTACHING lights, not the lights themselves. Download the file and you’ll get what I mean…
I’m waiting anxiously for the speakers… you actually don’t need textures since I can make my own in Photoshop. Also, is your stuff licensed for commercial use or just for personal use?
Thanks everyone! :D
Yes, they are usable for commercial renders…
Basically they are done, I just need to rig the movement on the mounting bracket, which I should be able to get done tonight. The box is UV mapped, but the speaker isn’t, (won’t take much time to map it…) and the color in the render is the ‘base’ color. All I was going to do was add a simple noise map to the displacement channel to add a little ‘texture’ to the box.
Which would you prefer Poser PP2 or DS .duf format?
DAZ format please.
Thanks for doing custom work for me… I never expected it! If you don’t mind, I’ll texture it and post it here for everyone to enjoy and use.
Do both formats, that way, those of us still using Daz 4.0 can use them too.
Finally done…took a little longer than expected. I ended up having to rebuild it, twice as there were a couple of problems with the first mesh when I went rig it for posing.
There’s a DS4.5 duf format (it will be in the Daz section at ShareCG) and a cr2 version.
Where can I find a basic Santa suit for Genisis, or one that can be fitted to Genesis? So far I’ve only found the hat.
Oh, and I’m using DS 4.0 by the way.
I’ll see what I can do…probably a single stem (geometry) with ‘billboard’ leaves and geometry flowers with some berries….probably won’t be done until the weekend.
I just tried to do a quick one using the Ivy generator in Blender, but I don’t have enough memory to do it and run renders of the current project…so the belladonna needs to wait a while.
Thanks everyone! :D
