Digital Art Zone
20 of 75
20
General Freebie Requests
Posted: 08 August 2012 08:37 PM   [ Ignore ]   [ # 286 ]
Active Member
Avatar
RankRank
Joined  2010-03-01
Alexa Sears - 08 August 2012 09:31 AM
I’m trying to find a free crawdad/crayfish and American belted kingfisher bird, but I’m not having much luck. I know about Emperor Ken’s birds, but as this is for the Freepository challenge, I can’t use his stuff.
Thanks in advance.
Alexa smile
Not a kingfisher per say but you could redo his coloring:
http://www.sharecg.com/v/47128/View/11/Poser/Noviskis-Woodpecker-for-Poser
Not a crawfish but they are mini lobsters so changing the color of this dud might work:
http://www.shar3d.com/
Look for the Giant Mutant Lobster.
Profile
Posted: 09 August 2012 10:41 AM   [ Ignore ]   [ # 287 ]
Member
Avatar
Rank
Joined  2010-11-26
Just been scanning through ShareCG and ReRo Freebies… but didn’t have much luck in finding V4Male Textures for “normal” Chars (so not vampires or elfs…) Are there any at all?
 Signature
A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort.  ~Herm Albright
Profile
Posted: 09 August 2012 11:32 AM   [ Ignore ]   [ # 288 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
I only have one V4 male texture that I use, It is called Bruno, and is by RAMWolff
It was made for Vittorio, and includes a character, but can be used on V4 male.
Can’t find a link for it at the mo, but you could pop over here, and Ask him yourslef where he stores it
http://www.daz3d.com/forums/viewthread/5357/P15/#68579
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 09 August 2012 12:30 PM   [ Ignore ]   [ # 289 ]
Active Member
Avatar
RankRank
Joined  2010-03-01
chohole - 09 August 2012 11:32 AM
Cho could Blaze use the alternate UV Map trick? If you have 4.5 you can load a Micheal object UV set and use any of the M4 textures.
Profile
Posted: 09 August 2012 12:50 PM   [ Ignore ]   [ # 290 ]
Member
Avatar
Rank
Joined  2010-11-26
@Dollygirl
That UV Map trick is a nifty idea, but I’m looking for textures for someone whose computer isn’t ‘good enough’ for ds4. should have mentioned that, sorry.
@chohole
Thank you oh Oracle smile I found him at the Freestuffsection on Renderosity… there’s even a Version for Poser and one for DAZ… awesome!
For anyone who is interested:
Poser Version: http://www.renderosity.com/mod/freestuff/details.php?item_id=39680
DAZ Studio Version: http://www.renderosity.com/mod/freestuff/details.php?item_id=39679
Thanks again smile
 Signature
Profile
Posted: 09 August 2012 12:51 PM   [ Ignore ]   [ # 291 ]
Member
Avatar
Rank
Joined  2006-04-15
There’s a trick for swapping UV maps between Gen4 characters that works in DS3. The tutorial’s on the archive, so the images are missing, but it’s still usable.
http://forumarchive.daz3d.com/viewtopic.php?p=2249531#2249531
 Signature
“Why’s all the rum gone?”  *looks at the last render*  “Oh. That’s why the rum’s gone…”
DAZ Studio 3.1.2.32 | Windows 7 Pro SP1 x32 | ATI Radeon HD 4200
Say YES to David 5!
Profile
Posted: 09 August 2012 12:53 PM   [ Ignore ]   [ # 292 ]
Active Member
Avatar
RankRank
Joined  2010-03-01
BlazeMystEra - 09 August 2012 12:50 PM
@Dollygirl
@chohole
Thanks again smile
Well you just made is easier. When using DAZ3 there is a tutorial for you:
Using Textures
Profile
Posted: 10 August 2012 01:29 AM   [ Ignore ]   [ # 293 ]
Member
Avatar
Rank
Joined  2010-11-26
Thank you ThinMick and Dollygirl, both Links are very helpfull smile
 Signature
Profile
Posted: 10 August 2012 02:05 AM   [ Ignore ]   [ # 294 ]
Member
Avatar
Rank
Joined  2006-04-15
@BlazeMystEra: No problem. You just gave me the extra push to extend adamr001’s old tutorial to end with creating CR2s so you can load figures with pre-swapped UV maps.
And now that I’ve been a nerd… Has anyone seen a straight razor? Just a good old fashioned Sweeney Todd looking thing. Preferably posable, but at least available in the open position.
 Signature
Say YES to David 5!
Profile
Posted: 10 August 2012 03:16 AM   [ Ignore ]   [ # 295 ]
Active Member
Avatar
RankRank
Joined  2011-11-16
I could use a couple of freebie conforming hair styles that can be used for commercial renders and are compatible with Genesis figures (either as V4/M4A4/H4 hair or made for Genesis). The first needs to be something similar to Ice-Boy’s “Slic Hair”. The second needs to be pulled back into a long ponytail at the nape of the neck (no bangs).
I’ve looked through the freebie links thread and cannot find what I need.
Profile
Posted: 10 August 2012 09:25 AM   [ Ignore ]   [ # 296 ]
Active Member
Avatar
RankRank
Joined  2010-03-01
Tramp Graphics - 10 August 2012 03:16 AM
Tramp,
These two are for V3 but I have used both with V4 by resizing and then parenting.
Flo Hair, has a tie back option as one of the morphs.
http://www.morphography.uk.vu/dlflo2.html
All Back Hair, 2nd one down.
http://digitalbabes.jp/
Profile
Posted: 10 August 2012 12:34 PM   [ Ignore ]   [ # 297 ]
Active Member
Avatar
RankRank
Joined  2011-11-16
Dollygirl - 10 August 2012 09:25 AM
Tramp,
I’ll give them a try. I’m using them on three male Genesis (the short hair on one, the ponytail on two others)., so I don’t know if these will work at all.
Profile
Posted: 11 August 2012 01:34 AM   [ Ignore ]   [ # 298 ]
Addict
Avatar
RankRankRankRank
Joined  2006-02-20
ThinMick - 10 August 2012 02:05 AM
Not sure what you mean with straight ...
http://www.wg3d.com/downloadsx.html
or
http://www.sharecg.com/v/3089/View/1/3D-and-2D-Art/Gillette-MACH3-01
 Signature
I like Bryce, DazStudio, Poser and Vue ... in alphabetical order. And I would probably like Carrara too, if I could find the time to become acquainted with it. Peace?
Profile
Posted: 11 August 2012 04:24 AM   [ Ignore ]   [ # 299 ]
Member
Avatar
Rank
Joined  2006-04-15
Kerya - 11 August 2012 01:34 AM
That one! And I looked at that page like three times, the other day, before I posted this, and didn’t spot it!
Tch, shame on me. Thank you.
 Signature
Say YES to David 5!
Profile
Posted: 11 August 2012 12:59 PM   [ Ignore ]   [ # 300 ]
Member
Avatar
Rank
Joined  2010-12-19
Thank you, Ms. Chohole and Ms. DollyGirl, for your help! smile
Alexa
 Signature
守 (Protector, Mamoru)
No Post-work zone… EVER
Software efficiency halves every 18 months, thereby compensating for Moore’s Law.
Profile
20 of 75
20
