Digital Art Zone
How to export categories
Posted: 13 August 2012 02:18 AM   [ Ignore ]
New Member
Joined  2012-04-02
I’ve organized all my items into individual categories.
I did it by right clicking every item and choosing “Categorize…”.
Now I’ve installed DAZ on another computer and I’d like to have the same categories there.
But I really don’t wanna do all the work again.
Is there any chance to export my categories/structure to the other computer?
I couldn’t find any command…
Profile
Posted: 13 August 2012 04:45 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
I think you will need to wait for Adamr001 to see your post, I think he is the only one that can answer it for you.
I know that there is a folder called Content Management Service in the Program Files\DAZ 3D folder, which you should probably backup anyway, but whether it can be transferred to another computer without any extra work, I just don’t know.
Profile
Posted: 13 August 2012 05:42 AM   [ Ignore ]   [ # 2 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Adam’s tutorial is here:  http://forumarchive.daz3d.com/viewtopic.php?t=179107
To see the images you need to add “forumarchive.daz3d.com/” in front of the “postimages” text.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 13 August 2012 07:40 AM   [ Ignore ]   [ # 3 ]
New Member
Joined  2012-04-02
thanks for the reply!
But I still can’t solve my problem.
Recording to the tutorial, I have to find a folder called “Content Management Service”.
Unfortunately I can’t find it anywhere…
You should know that I’m using Mac OSX (10.7). Does this make a difference?
fixmypcmike - 13 August 2012 05:42 AM
Why don’t you change/correct the links as an admin? wink
Profile
Posted: 13 August 2012 07:41 AM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Because someone forgot to issue the Mods with the right Magic wand ?
Adam is actually working on replacing his tutorials, but do give him some time, it is not an easy task, and like all of us on the team he is a volunteer, and does have a RL job as well, a very stressful and demanding one.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 13 August 2012 07:45 AM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
Re:Migrating Categories tutorials… If you’re using DS4.x then the pictures in the migration tutorial weren’t really necessary anyway.  If you’re using 3.x, I wasn’t intending on redoing those tutorials as DS3 is more than a year out of date now.
 Signature
My Tutorials and Freebies Index
Profile
Posted: 13 August 2012 07:51 AM   [ Ignore ]   [ # 6 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
Eh, give me a bit, I’ll redo it smile
 Signature
Profile
Posted: 13 August 2012 08:30 AM   [ Ignore ]   [ # 7 ]
New Member
Joined  2012-04-02
adamr001 - 13 August 2012 07:45 AM
Are you refering to where you talk about “fix the categories”?
The problem is there are no big yellow exclamation points!
I made a regular install of DAZ. Then I’ve installed every single Item with the related installer (also added all the meta data).
So the migration I’m looking for is not such large as in you tutorial.
Everything already works. All the content is available.
I just want to copy the structure of my categories to the other computer so that i doesn’t have to categorize everything again.
That isn’t such simple as I thought, is it?
(I hoped that I just have to copy some file(s) where the structure is saved)
I’m using DS 4 64bit on Mac OSX.
adamr001 - 13 August 2012 07:51 AM
What do you mean? What will you redo?
Profile
Posted: 13 August 2012 08:33 AM   [ Ignore ]   [ # 8 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
That is covered by my tutorial.  You have to copy the database from the old computer to the new just as if you were doing a complete migration.  The yellow exclamation points only appear if the location of the content has changed.  If you copied things over to an identical path, then you won’t have to do that part of the tutorial.
Here’s the redone tutorial:
http://www.daz3d.com/forums/viewthread/5639/
 Signature
Profile
Posted: 13 August 2012 09:30 AM   [ Ignore ]   [ # 9 ]
New Member
Joined  2012-04-02
adamr001 - 13 August 2012 08:33 AM
the problem is I can’t find these files.
in your tutorials you’re talking about this
* Path for Content Management Service
*  * E:\DAZ\Content Management Service
* Path for CMS Databases
*  * E:\DAZ\Content Management Service\databases
But when I go into my Programs-Folder I can’t find these folders… :(
http://img6.imagebanana.com/img/3pf3sfcl/Bildschirmfoto20120813um17.29.16.png
Profile
Posted: 13 August 2012 10:08 AM   [ Ignore ]   [ # 10 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
The default location for the installation of the CMS database on OSX is: /Users/[YourUsername]/Documents/DAZ 3D/CMS/databases
As shown here: http://daz.tall-tales-racing.com/resources/tut/basics/B2B_OSX_DS4_install_files/image020.jpg
 Signature
Profile
Posted: 14 August 2012 02:17 AM   [ Ignore ]   [ # 11 ]
New Member
Joined  2012-04-02
is it possible to run daz without the CMS?
I’m asking this because I can’t find this folder:
http://img6.imagebanana.com/img/gf61ckjj/Bildschirmfoto20120814um10.06.36.png
unfortunately the installation has been a long time ago, but I’m pretty sure I didn’t choose a custom path during the installation.
even the mac search programm can’t find a folder called ‘CMS’
Do you have any idea of what to do?
*edit*
ok, I’ve found it smile
it’s ‘Library/DAZ 3D/Content Management Service/databases/’ (excluded from the search?)
now I’ll try copy the content of this folder to the other computer and tell you if it works…
Profile
Posted: 14 August 2012 09:03 AM   [ Ignore ]   [ # 12 ]
New Member
Joined  2012-04-02
bad news: it didn’t work :(
i copied and replaced all database files.
then I did the same with the mentioned folders of the tutorial (plugins, resources, scripts, service, shaders).
But I still can’t see my individual categories.
Any idea what’s the problem?
Profile
Posted: 14 August 2012 09:14 PM   [ Ignore ]   [ # 13 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Are you seeing any categories?  Did you make sure the CMS service was stopped on both machines when you moved the database files?
 Signature
Products In Zips
Profile
Posted: 17 August 2012 02:52 AM   [ Ignore ]   [ # 14 ]
New Member
Joined  2012-04-02
yes, I tried again and checked whether the CMS is stopped on both machines.
then I copied again all files from my ‘database’ folder.
But I still can’t see my categories on the other computer… there’s still only the category ‘default’ :(
Profile
Posted: 17 August 2012 07:45 AM   [ Ignore ]   [ # 15 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
Then either the database you copied isn’t the right one or you’re copying it to the wrong location on the new computer.
The easiest way to figure this out is to “re-install” DAZ Studio on each machine.  Make sure and do a “custom” installation and to “Customize the CMS install” as well.  During this process, when it gets to the CMS install portion it will fill in the data that shows you where your databases are located.
Just to be certain, you’re going from OSX to OSX and not something like going from Windows to OSX right?
 Signature
Profile
