Digital Art Zone
I need Help with making a License Plate for a Model
Posted: 12 August 2012 09:06 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2003-10-09
I’m having a hard time with the raised Letters/Numbers part of the License Plate. I have been trying to use a gray scale bitmap in the bump channel but I don’t see difference in height. I have tried using 60% for the lower outer ring, 50% for the base of the Plate and 0% for the Lettering (% of Black) and 100% for the lower outer ring, 50% for the base of the Plate and 0% for the Lettering (% of Black). Each color does have sharp edges, if that makes a much of a difference.
Link to a picture of a real License Plate…
http://upload.wikimedia.org/wikipedia/en/f/fc/Kansas_license_plate.jpg
Thanks,
Profile
Posted: 12 August 2012 09:26 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2006-08-27
Might it work as a displacement map instead?
Profile
Posted: 12 August 2012 09:30 AM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2003-10-09
evilproducer - 12 August 2012 09:26 AM
I never had much luck with displacement maps at all. When I tried it this time it went all black for me.
Profile
Posted: 12 August 2012 02:21 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  0
Turk_WLF - 12 August 2012 09:06 AM
Thanks,
A bump map should work pretty well. It doesn’t create actual geometry, just a lighting effect at render time.
Use a Gaussian Blur on your black and white bump map to simulate rounded edges.
Here’s an image map, followed by the bump map, followed by the Carrara render.
(Click the image for a larger version.)
Image Attachments
 Signature
-Dean
Profile
Posted: 12 August 2012 11:56 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
I took the liberty of downloading your example image - simply made a greyscale and reversed - used a grid set to the proportions of the original.  Placed the original in the colour channel and the greyscale in the bump channel.
Image Attachments
Profile
