Digital Art Zone
How do you make a camera follow a character
Posted: 11 August 2012 08:30 PM   [ Ignore ]
New Member
Joined  2012-06-22
Hello everybody.
I am new to this. But in Daz I am trying to make a camera follow the character when he walks. How would I go about doing this. I tried to parent the camera but that Failed so I am trying to find out the best solution to this.
thank you.LOL
Profile
Posted: 11 August 2012 09:06 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
With the camera selected, go to the Parameters tab and click on “Point At”, then select the person or the person’s head for it to point at.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 11 August 2012 09:10 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  2012-06-22
fixmypcmike - 11 August 2012 09:06 PM
Thank you for your reply. I tried the point at but it justs turns to the character and rotate but dosent move with the character. I am trying to have the camera move with the character. Is there a way to do that? Or a easy way todo that. I know your can key animate it. But I want to know if there is a work around. Thanks.
Profile
Posted: 11 August 2012 09:13 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2006-06-12
It has been a long time since I have done this with DS.
You could try parenting the camera to the figure’s waist.
It should move when the character moves.
You could also try parenting the Figure to the camera.
Best of luck!
 Signature
There is a serious tendency toward capitalism among the well-to-do peasants.
Mao Tse-Tung
Profile
Posted: 11 August 2012 09:20 PM   [ Ignore ]   [ # 4 ]
New Member
Joined  2012-06-22
tsarist - 11 August 2012 09:13 PM
You could try prenting the camera to the figure.
Best of luck!
Thank you for your reply. But i did try to parent already before and the camera moves and wobbles at the same time maybe i am doing iit wrong how do you normally parent?  Thanks.
Profile
Posted: 13 August 2012 11:11 AM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2012-05-25
one of the basic things you need in animation setup.
add camera to motionpath.
unthinkable this feature is not available in studio.
Profile
Posted: 14 August 2012 01:49 AM   [ Ignore ]   [ # 6 ]
Power Member
Avatar
RankRankRank
Joined  2012-03-24
my way to keep camera distance and angle with genesis of other figure,
first create null, or some visible primitive from top menu>create.
then name as “camera mover” for you can check it easy.
and select genesis and camera , then parented to “null” by drag them in scene tab.
or right click and change parents.
then move genesis by mover.  you can keep angle and distance.
Image Attachments
Profile
Posted: 14 August 2012 02:12 AM   [ Ignore ]   [ # 7 ]
Power Member
Avatar
RankRankRank
Joined  2012-03-24
if you want to make run effect, make some runiing pose with not move hip translation,
( as if gensis training by runningmachine in the room)
then translate genesis positon where you want by null mover.
and set keyframe.
the seanes (or ground)  move so genesis can run. (real animate way I think,,)
Profile
Posted: 16 May 2013 09:47 PM   [ Ignore ]   [ # 8 ]
New Member
Joined  2012-06-22
———> Me
Late reply. Thank you
Profile
