Digital Art Zone
Moving compressed/zipped files?
Posted: 10 August 2012 04:57 AM   [ Ignore ]
Member
Rank
Joined  2011-12-14
Downloading frebies has eaten my hard drive space (the C drive that is). Once I’ve unzipped a freebie so that there’s now a zipped file and a file folder with the same name in My Library is it safe to move to a different drive or delete the zipped/compresed file so it’s no longer taking up room, or does DS need the zipped file in My Library in order for the prop /freebie to work?
In other words, when I’m loading a prop into DS, does it access or use the compressed/zipped folder or just the unzipped file folder that has the same name?
I hope this question is clear, I’m not good when it comes to messing with files.
Profile
Posted: 10 August 2012 04:59 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2010-10-10
DS only uses the unzipped contents of the folder.
You can safely delete the zipped file. I only save the zipped file to an external drive if I want to keep it as it will take up less room.
 Signature
Wendy
My freestuff: http://www.sharecg.com/pf/full_uploads.php?pf_user_name=Wilmap
My Deviant Art Gallery:  http://wilmap2.deviantart.com/
Profile
Posted: 10 August 2012 05:24 AM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2011-12-14
wilmap - 10 August 2012 04:59 AM
Cheers for the quick reply. That’s just the answer I was hoping for.
Also thanks for making freebie clothes for Genesis, I’ve been using them quite a bit.
Profile
