DAZ Studio Installation Guide Mac
DAZ_bfurnerDAZ_bfurner Posts: 63
edited August 2012 in Daz Studio Discussion
DAZ Studio 4 Installation Guide
Contents:
1. Determining if your computer is 32 or 64 bit
2. Installing DAZ Studio 4
a. License Keys
b. OS 10.8 Security Settings
c. Content Management Service
Determining if your Mac is compatible for 32 or 64 bit
In order to install DAZ Studio 4, you have to determine which installation file to run. Follow these instructions to determine which file your Mac hardware and OS will be compatible with:
1. Select About This Mac from the Apple icon.
2. Select the More Info... button
3. Select System Report
4. Open the Hardware heading
5. Locate the Processor Name
6. Compare your Processor Name to the specifications below to determine 32 or 64 bit compatibility
7. Run the appropriate installation file to begin installing DAZ Studio 4.
Installing and Running DAZ Studio 4
License Keys
Upon running DAZ Studio 4 for the first time, it will prompt you to enter a license key. You may run DAZ Studio 4 without a license key as a demo edition. However this will limit some of the functions and features that the full program will offer.
You may access a DAZ Studio 4 Pro Edition license key free of charge fro a limited time through the online DAZ 3D Store (follow the hyperlink above). After completing the check-out of the DAZ Studio Pro product from the store, access the license key from the My Account page under the My Serial Number menu option.
Copy and paste the License Key into DAZ Studio 4.
Mac OS 10.8 (Mountain Lion) Security Setting
Mac OS 10.8 (Mountain Lion) default security settings prevent unidentified developed applications to be installed on the Mac OS 10.8.
If you do not adjust this default setting in your Security Settings, you will get a warning window when launching the DAZ Studio 4 installation file.
In order to install DAZ Studio 4, you will have to adjust the default security setting.
1. Open System Preferences
2. Select Security & Privacy
3. Under Allow applications downloaded from:, select the Anywhere option
* After installing DAZ Studio 4 you may return the security setting to it's default.
If you choose the Custom installation option, the install wizard will prompt you to also install the Content Management Service. This program provides many features and functions that make DAZ Studio 4 easier to interact and render with different content packages (plugins, skins, clothing conforming, etc.). If you did not choose the Custom option, then this program is automatically included.
The Content Management Service is not required to run DAZ Studio 4. However it is highly recommended if you wish to enjoy the full complement of features and conveniences offered by DAZ Studio 4.
The following pictures added may be out of order, but they can be helpful in the process. Sorry if they are not appearing in the right order, it is a problem with images in the forums right now.
537 x 697 - 87K
535 x 707 - 91K
527 x 677 - 93K
545 x 717 - 98K
Post edited by DAZ_bfurner on
  • this needs to be updated because most new macs are 64bit - and running on newer operating system
  • MiloMilo Posts: 470
    I saw something interesting that was using eGPU connected through thunderbolt.  They had an NVidia card running that way.  I wonder if Iray would use it
  • I bought a BizonBOX with a NVIDEA TITAN X in it, and it sped things up a lot. But when I updated to the High Sierra OS, it quit working. I'm sorting that out now with the BizonBOX techs.
  • EsemwyEsemwy Posts: 475
    This thread got me there with my eGPU.
    Thanks for the Info, so when you say sped it up a lot, I take it that the Iray renderer saw the GPU and utilized it.
