Digital Art Zone
SDiv 4 GoZ ,bad results ,Help
Posted: 07 August 2012 11:17 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2003-10-09
It’s all explained here.
http://www.zbrushcentral.com/showthread.php?170495-SDiv-4-GoZ-bad-results-Help
Profile
Posted: 08 August 2012 12:19 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2009-08-05
You need to smooth the mesh. Hold shift and brush. But do not smooth at the highest sub-d level and DO NOT over smooth or you loose the original shape.. Do it at sub-d lvl 2 and then switch to 4 to see what difference it made. I hope you know that the model has to be set back to base sub-d 1 if you want to use it in Daz again. You only Sub-d to level 4 for displacement maps and normal maps details.
 Signature
My Daz Store
My Rendo Store
Latest Products
FaceWeight for Genesis
Toe Control for Genesis
Profile
Posted: 08 August 2012 02:14 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2003-10-09
If you click Geometry / Rstr before you slide SDiv back to 4 ,Does the trick.
Profile
