Digital Art Zone
4 of 6
4
Learning UberEnvironment 2 Return To Topic
Posted: 27 November 2012 06:06 AM   [ Ignore ]   [ # 46 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
I agree 100% with Adam on this. Saturation is connected to the HDRI map which controls how much colour comes form the HDRI map.
 Signature
Pete
Somethings to Consider when starting to learn CG
My Gallery
My Render Thread and Tutorials
Proud member of the Bald Wizards Club and Co-operative
Facebook
Profile
Posted: 27 November 2012 06:35 AM   [ Ignore ]   [ # 47 ]
Member
Rank
Joined  2012-02-04
I think… no, I’m absolutely sure (: that I’m not understanding something here.
If saturation is about HDRI map and controls color, shouldnt the reds on that first examples of 0% and 100% have some variation?
I understand what Adam said about difuse color not being changed, but there wouldnt be some influence from HDRI map on the final color with such huge change in saturation?
{}fatbear
Profile
Posted: 27 November 2012 07:04 AM   [ Ignore ]   [ # 48 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
That will depend on your HDRI map and how saturated the map is.
Take the Moon/Night time UE2 preset…..makes everything a heavy blue when rendered, lower the saturation down to 50% and do another test render and you should see how lighter the blue lighting effect is.
 Signature
Pete
My Gallery
Facebook
Profile
Posted: 30 November 2012 05:09 AM   [ Ignore ]   [ # 49 ]
Member
Rank
Joined  2012-02-04
Szark - 27 November 2012 07:04 AM
Yes, true, but in this case the blue is part of what we’re calling shadow (the part added by UE2 to the image). So surely changing saturation will change the blue (and also the rest of the colors, since the blue is a “layer” covering everything).
For a more productive question (:  Can we add other HDRI maps to UE2 or we’re restricted to the ones in it?
{}fatbear
Profile
Posted: 30 November 2012 05:51 AM   [ Ignore ]   [ # 50 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
The Blue light coming from the HDR/Tif map flooding the scene with blue light, 360 degrees, well spherical really. So lowering the saturation lowers the effect of the coloured light map hence lowering the colour in the scene
yes it does generally again depending on the map used for the light
The shadowing, in the case of UE2 is Ambient Occlusion where we have a separate colour channel for that.
You can use HDR in HDR format but you will first need to convert it in to a TIf format via the built in Converter. Or purchase already formatted sets from the store.
The converter is easy to use. open it, browse to the HDR, selected, convert it. Then in the UE2 parameters go to the colour channel, Browse to the converted map and select.
One thing you have to remember the lighting will be as good as the map and some maps are bad.
 Signature
Pete
My Gallery
Facebook
Profile
Posted: 30 November 2012 06:28 AM   [ Ignore ]   [ # 51 ]
Member
Rank
Joined  2012-02-04
Szark - 30 November 2012 05:51 AM
Great!! I will try these too. I end using only UE2 in the default format, the others all have too intense global color. They can be great for some specific situations, but I want more “normal” HDR lights.
So one more topic to add to the immense list of things I want to learn (:
{}s
Profile
Posted: 01 December 2012 06:12 AM   [ Ignore ]   [ # 52 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
When you say normal are you meaning more realistic? I here you on that. I have been thinking of buying Dimension Theroy’s Urban Light pack, not for the background or shadow catcher just for the HDRI’s. I use the HDRI’s from the Azure Skies pack. It was made for Light Dome Pro 2 which doesn’t work in DS4/4.5 and uses converntioanl lights but the pack does come with HDRI equivilents, so I use the Background (sky dome) and HDRI in UE2 so I have matching skies and lighting.
 Signature
Pete
My Gallery
Facebook
Profile
Posted: 03 January 2013 12:19 PM   [ Ignore ]   [ # 53 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
Okay… had to come back to this thread because I sort of discovered a new setting…
I have two renders here.  The lighter one is the default setting on Environment Mode: Occlusion with Directional Shadows.
The darker one is GI…
I thought UE2 WAS GI!  What part did I miss?
Image Attachments
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 03 January 2013 12:24 PM   [ Ignore ]   [ # 54 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
GI Only works via the GI Loading Preset next to the Base Icon. Loading a Base and changing it to GI in the Parameters Pane won’t work. smile
 Signature
Pete
My Gallery
Facebook
Profile
Posted: 03 January 2013 12:56 PM   [ Ignore ]   [ # 55 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
Szark - 03 January 2013 12:24 PM
Thanks, Szark… that finally is getting through my head smile
adamr001 - 08 August 2012 11:03 AM
Muon Quark asked: So I wonder what would happen if you turned down the intensity of the light and used 0% contrast. If you turned the intensity down far enough, would it make the objects appear to glow? And if you also used a high ambient setting on the object, would that help with the glow effect? I think I will have to experiment with that today.
My theory at this point: I believe you will lose the light “bounce” with a lower intensity thus reducing / removing the color bounce effect.
Okay, I found out something interesting just now.  If I lower the intensity I do, in fact, lose that colour bounce, but if I double the intensity scale, I seem to get it all back.  Have you explored that yet?
 Signature
My ShareCG Gallery
Profile
Posted: 03 January 2013 01:14 PM   [ Ignore ]   [ # 56 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Depends what we are talikng about now..still GI?
This is part of what I know about Uber GI http://www.daz3d.com/forums/viewthread/12654/P60/#197187 and the other part is that the Uber GI itself isn’t a light source (I can’t check as my main machine is dead) But I do know for sure that it doesn’t use a HDRI map at all and therefore many controls don’t effect what the GI preset does. I haven’t fully explored GI as it takes forever to test anything but when I get a new machine I am going to expore so much more. smile (refering to the link above) Plus I am not sure if Max RayTrace Depth does refer to how many light bounces there are but for me it makes sense. wink
 Signature
Pete
My Gallery
Facebook
Profile
Posted: 03 January 2013 01:24 PM   [ Ignore ]   [ # 57 ]
Power Member
Avatar
RankRankRank
Joined  2006-03-14
Re: GI mode… What GI mode in UE2 means is that it is the “bounce” calculation provided by IBL w/Direcitonal Shadows mode without the primary light cast by the IBL map (You end up with just the bounce, that’s why it says “Bounce Light (GI)”.  The Bounce Light mode should only be used when other lighting is the primary source of light in the scene. This will give you the color bouncing of objects without taking the full IBL mode render time hit (in theory anyway).
 Signature
My Tutorials and Freebies Index
Profile
Posted: 03 January 2013 01:31 PM   [ Ignore ]   [ # 58 ]
Power Member
Avatar
RankRankRank
Joined  2006-03-14
Examples coming momentarily that will make it clear I believe.
 Signature
Profile
Posted: 03 January 2013 01:41 PM   [ Ignore ]   [ # 59 ]
Power Member
Avatar
RankRankRank
Joined  2006-03-14
First up a simple plane, sphere and distant light…
Image Attachments
 Signature
Profile
Posted: 03 January 2013 01:42 PM   [ Ignore ]   [ # 60 ]
Power Member
Avatar
RankRankRank
Joined  2006-03-14
Same thing, same scene but I added UE2 in bounce mode with the KHPark prreset…  You can see how the “bounce” has lightened the shadow cast by the raytrace distant light, lightened the bottom of the self-shadowing on the sphere (bounced light from the plane) and bled red into the area around the sphere on the plane (bounce from the sphere onto the plane).
Image Attachments
 Signature
Profile
4 of 6
4
