I’m going to be using Genesis in Carrara 8.5 beta (and C8.1 Pro).
What are the best (or some options) for getting the Genesis body textured initially - I’ll need both dark and light skinned individuals, young and old, male and female - and I will be doing everything based of the Female Genesis form (which as I understand should be compatible with V4 textures).
Does Carrara let you use some formats of DAZ MAT files but not others? (some seemed to work with drag and dropping others didn’t)
And what about applying the .png files as textures in the Shader room? That didn’t work. Do I need to do something inside of Carrara to get Genesis UV Mapped or does it come in already mapped?
Thanks for any suggestions about products or methods.
I also tried multiplying texture with a color to get a darker skin texture but did’t have great results. May just require some more experimentation or better base texture, but any suggestions as to method are welcome.
(I will be texturing the face separately through FaceGen and would ideally match the texture colors so face/nexk etc match.
Thanks
