Digital Art Zone
1 of 2
1
Putting a light in a lighthouse
Posted: 06 August 2012 05:24 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2010-10-10
Very new to Bryce, but i would like to put a light in a lighthouse.
I have managed to add a light but can’t get it to spread out like a lighthouse would.
Any help would be appreciated.
 Signature
Wendy
My freestuff: http://www.sharecg.com/pf/full_uploads.php?pf_user_name=Wilmap
My Deviant Art Gallery:  http://wilmap2.deviantart.com/
Profile
Posted: 06 August 2012 07:22 AM   [ Ignore ]   [ # 1 ]
Power Member
RankRankRank
Joined  2011-11-16
I haven’t done Bryce in a long time but I think you want a volume with cloud noise and some ambiance assigned.
 Signature
Just because I may have a strong opinion doesn’t make it any more (or less) correct than any other, just that I feel passionately a particular way at that moment.
Profile
Posted: 06 August 2012 07:54 AM   [ Ignore ]   [ # 2 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
In the Light Lab, set the spot light to Visible Object. Try either surface (renders faster) or Volume.
 Signature
**  [ Stuff by David Brinnen and Horo**  [ My Website**  OPC 4565 **
Profile
Posted: 06 August 2012 08:22 AM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
sort of like tthis ? I used a radial and a spot.
Image Attachments
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge for June        June Freebie Challenge
11915 was the number
Profile
Posted: 06 August 2012 08:46 AM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Or maybe fake it with a cone and a texure, like the old Br5 “lit rays”, only this time I need to play and get the fall off on the texture going in reverse.
Image Attachments
 Signature
Profile
Posted: 06 August 2012 09:03 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2010-10-10
Thank you Gedd, Horo and Chohole for your advice.
Will now go and play and see what I can come up with.LOL
 Signature
Wendy
Profile
Posted: 06 August 2012 11:07 AM   [ Ignore ]   [ # 6 ]
Power Member
Avatar
RankRankRank
Joined  2004-10-01
More like this one: http://www.bryce5.com/details.php?image_id=563 it should fade into the distance. If you go rather for a look shown in chohole’s picture, get the free Streaming Rays from here: http://www.bryce5.com/details.php?image_id=1144 curtesy by Denny Markovic aka Frozencry.
 Signature
Profile
Posted: 06 August 2012 12:31 PM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  2004-06-24
You could also try a spotlight as a visible object and use “ranged” in the light lab to set the distance of visibility
Cheers
GG
 Signature
WHO said Kiwis can’t fly ?????
Profile
Posted: 06 August 2012 12:33 PM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2010-10-10
I have used the info given here and posted my image in the AUGUST New Users Contest WIP Thread. Thank you all for your help.grin
http://www.daz3d.com/forums/viewthread/5084/P60/#66314
 Signature
Wendy
Profile
Posted: 06 August 2012 04:29 PM   [ Ignore ]   [ # 9 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
OK I know I’m a bit late to this party, but I wanted to see if I could find an alternative way to the ones suggested.  I tried no end of volume light and materials (but they stop working when HDRI are loaded) - so that was no good… and well, cut a long story short, this is what I came up with.  It’s not exactly suited to beginners, but it might be of passing interest to some of the other posters.
Bryce lighthouse “light beam” effect - a 15 minute tutorial by David Brinnen
Image Attachments
 Signature
that Bryce Tutorials Info and this Products made by Horo and myself
Profile
Posted: 06 August 2012 04:55 PM   [ Ignore ]   [ # 10 ]
Power Member
Avatar
RankRankRank
Joined  2007-12-10
Dang, you make it look so simple David. grin
I wish I’d have had that tutorial last year when I did this one.
Image Attachments
 Signature
I’ve got nothing of my own to promote, no models, no tutorials, no website, nothin’, nada, nill, nowt.
Profile
Posted: 06 August 2012 05:01 PM   [ Ignore ]   [ # 11 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
Trust me Dave, if it was simple, I wouldn’t have nearly bitten my mouse mat in half in sheer frustration.  First Bryce can crash, then Camtasia can crash, then the video rendering can produce a file that crashes and then the whole maddening cycle begins over again.  And failing all else, youtube can just decide to sit with the video at 95% uploaded for hours at a time - apparently not doing anything very much.  Anyway, I hope you can follow the tutorial OK and it helps you in the future - even if it can’t help you in the past.
 Signature
Profile
Posted: 07 August 2012 04:19 AM   [ Ignore ]   [ # 12 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
I am going to have to find time to go through that Tutorial, super end result there David.  I guess it is not going to work in my normally used version of Bryce though.
 Signature
Profile
Posted: 07 August 2012 04:29 AM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2010-10-10
Lost me at the beginning! Will have to play with lights a bit more.
 Signature
Wendy
Profile
Posted: 07 August 2012 06:45 AM   [ Ignore ]   [ # 14 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
chohole - 07 August 2012 04:19 AM
There are ways and means, if you send me a stripped down source file with the lighting setup you imagine using I could probably figure something out as a compromise.  But really, all things considered, Bryce 7.1 Pro…  Can’t you sell a kidney or something, or better still, someone else’s?
 Signature
Profile
Posted: 07 August 2012 06:47 AM   [ Ignore ]   [ # 15 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-06
wilmap - 07 August 2012 04:29 AM
Yeah sorry Wendy, it was more of an alternative solution than an easy practical one.  But since all the easy options had gone, I wanted to offer up something else.
 Signature
Profile
1 of 2
1
