Digital Art Zone
24 of 46
24
Luke and Laura for Genesis, Genesis Teen Renders
Posted: 08 November 2012 10:01 PM   [ Ignore ]   [ # 346 ]
Active Member
RankRank
Joined  2011-04-12
wancow - 08 November 2012 07:36 PM
I can NOT see these:
Actor/Female/Real World/Tween Girl
Actor/Male/Real World/Tween Boy
I can, however, see these!
Actor/Head/Female/Real World/Tween Girl Head
Actor/Head/Male/Real World/Tween Boy Head
Actor/Upper Body/Torso/Female/Real World/Tween Girl Flat
Actor/Upper Body/Torso/Female/Real World/Tween Girl Rounded
All of them show up in the Parameters tab.  I just checked, and my Shaping tab (which I never use) matches what you describe.
(I wonder if this has the same root cause as the problems in DS4.0…)
Profile
Posted: 09 November 2012 03:25 AM   [ Ignore ]   [ # 347 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
Daz moved all the morphs to parameters since 4.0 - The announced that morphs were originally supposed to be in the parameters not shaping. I’m not sure if they intend to move it back or not. But you get used to using parameters smile
 Signature
I’m not Spyro the dragon… We just look alike! tongue wink
“Anything in the real world can exist in 3D”
Eyeshine Tutorial for Daz3D vampire
- - My Render Thread - - My Deviant Art - -
- - xSPYROx ShareCG Freebies - -
Profile
Posted: 09 November 2012 03:30 AM   [ Ignore ]   [ # 348 ]
Active Member
Avatar
RankRank
Joined  2010-10-10
Well I wish they would all show themselves in my Parameters tab. I still can only see the two Body morphs!
 Signature
Wendy
My freestuff: http://www.sharecg.com/pf/full_uploads.php?pf_user_name=Wilmap
My Deviant Art Gallery:  http://wilmap2.deviantart.com/
Profile
Posted: 09 November 2012 04:37 AM   [ Ignore ]   [ # 349 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
wilmap - 09 November 2012 03:30 AM
That is very odd. Are you using Ds 4.5 or Ds 4?? I’m Ds4.5 and I see it all. Have you tried re-installing it?
 Signature
Profile
Posted: 09 November 2012 04:55 AM   [ Ignore ]   [ # 350 ]
Active Member
Avatar
RankRank
Joined  2010-10-10
I’m still using DS4 and yes I reinstalled it and they still won’t show anywhere. I can only see the ones I mentioned earlier.
 Signature
Wendy
Profile
Posted: 09 November 2012 05:01 AM   [ Ignore ]   [ # 351 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
Is there anything stopping you from upgrading to 4.5? It could be because genesis has been upgraded. Eg. Genesis Starter essentials is now at 1.6 - Not sure what GSE# Murg uses… But if Murg uses a later upgraded genesis then some morph issues may happen for those who use an earlier version.
 Signature
Profile
Posted: 09 November 2012 05:05 AM   [ Ignore ]   [ # 352 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
Also… The required product : Genesis Evolution has also been upgraded and could be another impacting factor to your current problem.
 Signature
Profile
Posted: 09 November 2012 08:46 AM   [ Ignore ]   [ # 353 ]
Active Member
RankRank
Joined  2011-04-12
Spyro - 09 November 2012 05:05 AM
If the full body morphs look right when applied, this isn’t part of the problem.
Profile
Posted: 09 November 2012 08:50 AM   [ Ignore ]   [ # 354 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
Hmmm. Well other than that, I have absolutely no idea why it isnt appearing for Wilmap.
 Signature
Profile
Posted: 09 November 2012 09:15 AM   [ Ignore ]   [ # 355 ]
Active Member
Avatar
RankRank
Joined  2008-11-10
4.5 files aren’t backward compatible with 4.0. The specification for DSON is in 4.5.
More items will be 4.5 only in the future (mainly because those can get the Poser companion files generated for them), so it’s really time to start looking at upgrading. Our future products will be 4.5 only as it’s way too much work to do 4.0, 4.5, and the poser files and still charge a fair price the items. Also it looks like HSS in 4.5 is supporting normal maps (unlike 4.0) so we may be moving forward with that, so we’re not doing bump and displacement maps.
Profile
Posted: 09 November 2012 09:20 AM   [ Ignore ]   [ # 356 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
Yes, they are in the parameters tab, Murgatroyd!  Thanks for the reminder smile
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 09 November 2012 09:24 AM   [ Ignore ]   [ # 357 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
Male-M3dia - 09 November 2012 09:15 AM
What’s the go with normal maps? I still use bump and occasionally displacement for the older characters.
I’s it something similar to Displace? Or is it actually affecting the geometry or something?
 Signature
Profile
Posted: 09 November 2012 09:27 AM   [ Ignore ]   [ # 358 ]
Active Member
Avatar
RankRank
Joined  2008-11-10
Spyro - 09 November 2012 09:24 AM
Basically, displacement actually moves geometry (which could cause pokethrough in clothing), where normal does the same thing without moving the geometry.
Profile
Posted: 09 November 2012 09:40 AM   [ Ignore ]   [ # 359 ]
Addict
Avatar
RankRankRankRank
Joined  2009-02-26
Now that’s use full! Does that mean it looses the realism of displacement? where for example, a vein displacement is actually 3 dimensional in the render, and if you were looking at it from the side it actually is an extrusion.
 Signature
Profile
Posted: 09 November 2012 10:11 AM   [ Ignore ]   [ # 360 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Normal maps use and RGB color map to represent the 3D space…so, think of it as a kind of ‘hologram’ for the surface being rendered.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
24 of 46
24
