Digital Art Zone
content management
Posted: 02 August 2012 12:40 PM   [ Ignore ]
New Member
Joined  2010-03-25
i downloaded user created content and i do not know how to get it into the daz directory so i can use it how do i do that
Profile
Posted: 02 August 2012 02:13 PM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  2008-05-05
I assume it’s in a zip file?
If you go into the zip file, there will either be a “my libraries” folder or a “runtime” folder.  Just drag those files into the folder containing your My libraries or Runtime folders.
 Signature
One in 150 children is diagnosed with autism. One is mine.
My deviantArt Gallery: http://karibous-boutique.deviantart.com/
Profile
Posted: 02 August 2012 02:37 PM   [ Ignore ]   [ # 2 ]
Administrator
Avatar
RankRankRankRank
Joined  2009-01-22
Not quite, the Runtime needs to be MERGED with the default Runtime inside My Library. If you do that it will add the content. You can not have one Runtime inside another Runtime, DS will only read the top one and ignore the one inside the other one.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 02 August 2012 08:36 PM   [ Ignore ]   [ # 3 ]
New Member
Joined  2010-03-25
Jaderail - 02 August 2012 02:37 PM
i have the location of the directory pinned to my comp when i unzip the files i unzip them to the desktop then transfer and merge the files, but some of the items refuse to show up
Profile
Posted: 02 August 2012 08:46 PM   [ Ignore ]   [ # 4 ]
New Member
Joined  2010-03-25
Emmettturner - 02 August 2012 08:36 PM
heres a example of what im having problems getting to run http://www.sharecg.com/v/60194/related/21/DAZ-Studio/The-Pin-Up-Girl-Pack-for-Genesis
Profile
Posted: 03 August 2012 01:52 AM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2005-09-05
Hi, if you have installed it and merged the folders then you will need to go to the content tab and search known drives for new files. You should be able to find them after doing this.
 Signature
Shadermixer tutorials and recipes
My Website
My ShareCG Gallery
Shadermixer Documents
Profile
Posted: 05 August 2012 10:19 AM   [ Ignore ]   [ # 6 ]
Power Member
RankRankRank
Joined  2011-11-16
If you have DS open when you move new data to the library/runtime folders it won’t show up untill you do a refresh or restart DAZ. To do a refresh you can right click on the ‘DAZ Studio Formats’ and/or “Poser Formats” in the content tab and select ‘refresh.’
 Signature
Just because I may have a strong opinion doesn’t make it any more (or less) correct than any other, just that I feel passionately a particular way at that moment.
Profile
Posted: 05 August 2012 12:52 PM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2009-01-22
Depending on your DS version that set is just morhps and will only show in the Shaping Tab or Parameters Tab when you have a genesis Selected in your Scene Tab. It does say in the info that the extra characters will only work if you have the other DS morphs installed. It does not say which packs, so who knows if they, the characters, will work or not.
EDIT: I looked at the files, if installed properly you should have about 10 new morphs and two characters, one Pin-up and one cartoon version of the pin-up. The file structure is correct. Did you Megre the Data folder with Your Data folder? ect ect ect… You can not have a My Library folder inside another My Library folder.
 Signature
Profile
