Digital Art Zone
PE waste
Posted: 31 July 2012 07:51 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2010-09-22
It is clear if one wants a descent realistic PARTICLE emitter EFFECT your gunna have to do it post edit, WHICH is problematic in it’s own right!  Specially with anything that needs MASKED! BUT!
IF ANY PE in carrara has an effect assigned to it such as a BLUR or an ARUA!, if it touches anything less OR another emitter the EFFECTS will be canceled out! WOW!
Also if you assign and effect to an OBJECT which is used in the emitter SAME STORY. AND if these OVERLAP with other PE your not gunna like what you see!
IE A smoke trail from 2 jet engines close to one another, WHOS PE trail will cross or even touch. THE EFFECTS will be canceled out. YOUR NICE say 12 % Blur between the 2 will have a sawtooth look of the SHAPE you used in the emitter! say a diamond!
AS far as I can tell you CAN NOT have ANY emitter objects, be them your own! OR say a diamond or square, whatever, to be emitted RANDOMLY EMIITED! such as rotation you JUST CAN’T! CAN’T BE DONE!
DO NOT USE carrara PE for anything you wish to look realistic! Post edit is your only answer! PE in carrara is a waste!
Profile
Posted: 01 August 2012 07:01 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2004-11-07
Did you file a bug report? The developers don’t read the forum and we can’t do anything about it.
 Signature
Profile
Posted: 01 August 2012 10:05 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2010-09-22
ManStan - 01 August 2012 07:01 AM
They are aware of it! I had the same complaint back in Carrara 6 and hadn’t used PEs much until now and Would of thought they would of fixed it by now.
I was wrong!
I know there are existing ISSUES/BUGS by no one responding to the threads…
If its ME / OPERATOR ERROR you will get all sorts of responses.
Profile
Posted: 01 August 2012 10:09 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  0
RichardChaos - 01 August 2012 10:05 AM
sounds logical. oh oh blank stare
 Signature
grab a cup and hang with us at My CAFE - CARRARA USERS GROUP
Profile
Posted: 02 August 2012 07:23 PM   [ Ignore ]   [ # 4 ]
Active Member
RankRank
Joined  2007-10-15
Excellent point. I especially think the ARUA cancellation is really bad, if that’s what you mean. Because in the real world arua’s don’t cancel, and stuff like that doesn’t happen. That’s a serious bug if it’s true. I can’t believe they’ve had arua cancellation for so long and it hasn’t been fixed yet. But I think you should be able to do some awesome PE in Carrara, and I think you can get some awesome effects. Isn’t there a button somewhere to cancel the PE cancellation or something? That’s really what they should have is an option for cancellation or no cancellation, unless people don’t want it.
Profile
