The only other thing i can think of, is a memory problem while rendering. Poser 9 is 32 bit and can only use approximately 3.6 gb memory (depending on the system, but the 32 bit limit applies, also when you are running it on a 64 bit windows). You can check the memory usage by opening the task manager (performance tab to see the usage, or the process tab to see if there are any other services that use a lot of memory).
In my experience sometimes very complex and large scene crash while rendering because of the memory usage , it can help to lower the bucket size.
