Digital Art Zone
Problem with pwShaders and Cameras?
Posted: 31 July 2012 06:47 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2005-02-25
I’m having a problem in Daz studio.  At first I thought it was if i used the perspective cameras- such as front, top, etc.  If I used those perspective to render, the picture renders black.  A regular camera does the same thing if I turn off perspective.  This leads me to think that the shaders rely on some kind of depth perspective to work, but it REALLY bothers me, because I can’t get the same look using perspective and a lot of toon images LOOK way better without perspective but the toon shader won’t work.
Really super frustrated!!! :(  Anyone know a work around for this?
Profile
Posted: 31 July 2012 07:29 AM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2004-11-07
The camera shouldn’t effect shaders at all. Lighting does.
 Signature
Profile
Posted: 31 July 2012 07:40 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2005-02-25
Camera definitely DOES affect- specifically the perspective setting on the camera. No lights in the scene at all- toons often don’t need it.  but if i render with perspective on it works fine, but if i render with perspective OFF it renders the figures black.
Profile
Posted: 31 July 2012 09:01 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2004-11-07
“No lights in the scene at all”
“but if i render with perspective OFF it renders the figures black”
Hmm wonder why.
The camera you use should make no difference, if it does studio is more F’ed up then I thought.
Personally I steer clear of perspective cameras because they always gives a render a fish eye look.
To me is seems if there are no lights in the scene yet the prospective camera renders as if there is, there is a bug in it, because it shouldn’t. With no lights in the scene it should render black regardless of what camera you are using.
 Signature
Profile
Posted: 31 July 2012 09:14 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  0
In DS when you don’t add lights to the scene it uses default lighting, which is a no-shadows distant light oriented in the same way as the camera.
Profile
Posted: 31 July 2012 09:18 AM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2005-02-25
Leana, I’m aware of that.
I just don’t get why the same camera, renders fine with perspective ON, and renders black with perspective off. Its a real bummer!
Profile
Posted: 31 July 2012 12:10 PM   [ Ignore ]   [ # 6 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
It does sound like a bug, so i would make a report. If you are wanting to render without lights try parenting a distant light to your camera, with Parent in place off so it matches the camera’s rotation, with luck that will work and give you the same behaviour as the “head lamp” DS uses with no lights.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
