Digital Art Zone
Hand Grenade ~ Very first W.I.P.
Posted: 29 July 2012 07:34 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2012-04-28
Figured its time to actually post something. Being completely new to all this I’m a little nervous.
Anyway, made this following a Geek at Play tut series. Still have to go thru the UV mapping part.
Ok let me have it… How bad did I do?  =/
Image Attachments
 Signature
~ Roy
I’m so confused!
Profile
Posted: 29 July 2012 09:29 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Hey, Roy, you did real good! - very neat and clean.
Only crit I have have is there is no hole for the pin - maybe a bit of thickness on the handle?  but that’s minor.
What does the underside look like - do the loops terminate in a pole with all tri’s, or have you made them into quads?
Profile
Posted: 29 July 2012 11:52 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2011-11-16
As someone who was in the Army, and has actually thrown those things, you did a bang-up job. It’s damn near perfect. Well done.
Profile
Posted: 30 July 2012 06:50 AM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2012-04-28
Roygee - 29 July 2012 09:29 PM
Thanks!
Yeah, I thought about the hole after I posted this last night. He didn’t do it in the tut so I didn’t even think of it till I was done. Gonna go back and try and put it in. And now that you mention it, the spoon could probably use a bit more thickness.
As for the underside? I could be wrong, still get a little confused on this part, but all the faces(?) along the very bottom have 4 sides so I am assuming their quads. Added a screen so you can see. Then maybe you can tell me, lol!
Image Attachments
 Signature
~ Roy
I’m so confused!
Profile
Posted: 30 July 2012 06:52 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2012-04-28
Tramp Graphics - 29 July 2012 11:52 PM
Thank you very much!  grin
 Signature
~ Roy
I’m so confused!
Profile
Posted: 30 July 2012 10:44 AM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2005-01-15
Well done Roy, I followed the same tutorial many moons ago and you made a better job of it than I did.
Profile
Posted: 30 July 2012 01:23 PM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2012-04-28
Wee Dangerous John - 30 July 2012 10:44 AM
Thank you, Wee Dangerous John!
Trust me, It wasn’t a one time run thru. It took many many tries to get it to where I was happy with it.  well… semi happy. Still think it needs a little tweaking. Hoping to have some time tonight to at least start the UV mapping.
 Signature
~ Roy
I’m so confused!
Profile
Posted: 30 July 2012 02:28 PM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Yes, they are quads, but still converge on a pole - this can cause a problem with some renderers.  I wouldn’t worry about it at this stage, but bear in mind for future - it’s good practice to avoid poles by reducing the edges converging on a point to four, as you can see in no 2 in my pic - this gives a nice finish and a neater mesh.
Same goes for caps on cylinders.
This really dates me - in my army time we used the old Mills grenade - chunky, heavy things - well-known as a Pineapple.
Image Attachments
Profile
Posted: 30 July 2012 03:14 PM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2012-04-28
Thanks for the advice, RoyGee! I’ll keep that in mind for the future. Would you recommend dissolving the edges or deleting them? I remember in one of the tuts I was watching one time(cant remember who’s) that one was better to do than the other. Gonna have to go back and see if I can find it again.
I remember the pineapple style grenades. Well, not by experience but the look of them. Was actually thinking of trying it out. Dont think it should be too hard to pull off.
 Signature
~ Roy
I’m so confused!
Profile
Posted: 30 July 2012 06:08 PM   [ Ignore ]   [ # 9 ]
Member
Rank
Joined  2009-01-27
GREAT job, Roy!!
The ONLY critique I have is that the body isn’t perfectly spherical; it’s slightly elliptical.
 Signature
For any arguments or illustrations I give, my system specs are:
Hexagon version 2.5.1.79,  XP pro 32 bit,  pentium core2 duo,  ATI radeon 3870, 2 gigs ram
Profile
Posted: 30 July 2012 06:18 PM   [ Ignore ]   [ # 10 ]
Member
Rank
Joined  2009-01-27
Roygee - 30 July 2012 02:28 PM
Good god, Roy!!! How old ARE you? Pineapples were WWII and possibly korea…I’m 64 and was in from 66-69 and we only had this type. I’ve never even seen a pineapple with my own eyes!
 Signature
Profile
Posted: 30 July 2012 11:00 PM   [ Ignore ]   [ # 11 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Like I said, this dates me - I’m 69!  Did my time 62-65.  The last grenade model I saw was like a small tin of beans - you left it “as is” for percussion, or slipped a steel coil with segments over it for shrapnel - a lot lighter and easier to throw than the old Mills.
Roy G - dissolve.  If you delete you’ll have holes.  The way you cast off is to select the last ring of edges and do an “extract along” inwards towards the centre point .  That makes quads between the old ring and the new and tri’s within.  Select each alternate edge within the circle and dissolve.  Repeat until there are only four edges converging on the centre point.
Profile
Posted: 01 August 2012 05:34 AM   [ Ignore ]   [ # 12 ]
Member
Avatar
Rank
Joined  0
This got me remembering.
I did make a pineapple grenade once.
I used it for a Easter picture…..
I have actually thrown one of these. Many,many years ago, But it was a dummy, for training.
And if I remember correctly… I failed…
Image Attachments
 Signature
My freebies : http://www.sharecg.com/pf/full_uploads.php?pf_user_name=Varsel
Profile
Posted: 03 August 2012 07:17 AM   [ Ignore ]   [ # 13 ]
Member
Avatar
Rank
Joined  2012-04-28
Sorry for just getting back to this. Had a little PC trouble.
Anyway… the UV mapping became a complete epic fail on my part. Haven’t given up on it, gonna keep trying. Just a little harder than I thought.
But I did get a little anxious to see it rendered. So I exported it out to Carrara and painted it in there. Just added a few basic shaders to it and dropped it into a lighting preset.
Image Attachments
 Signature
~ Roy
I’m so confused!
Profile
Posted: 03 August 2012 09:26 AM   [ Ignore ]   [ # 14 ]
Active Member
Avatar
RankRank
Joined  2011-11-16
Looking good. cool smile
Profile
Posted: 03 August 2012 05:49 PM   [ Ignore ]   [ # 15 ]
Member
Avatar
Rank
Joined  2012-04-28
Thanks! grin
 Signature
~ Roy
I’m so confused!
Profile
