Digital Art Zone
Painting on UV maps
Posted: 29 July 2012 05:12 PM   [ Ignore ]
New Member
Avatar
Joined  2004-10-05
Is there any way to paint or texture my own UV map in studio? I’m looking for the ability to paint and texture right on the mesh so the seams all line up as they should. I’ve tried the MLIE and it’s fine for some work, but it can’t wrap a new texture across seam edges, it just cuts them off. Is there a tool for OSX that would let me paint in this way as long as I own the mesh and the UV map? Does the Content Creation Toolkit let me do this? Thanx in advance!
 Signature
My deviantArt Gallery
Profile
Posted: 29 July 2012 06:10 PM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  2005-08-20
No.
Use Bodypaint, ZBrush, 3DCoat…
 Signature
*Sigh* Window->Tabs->Tool Settings->Draw Style->Manipulation: Off
Yeah. It’s like that.
Profile
Posted: 29 July 2012 07:39 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2003-10-10
Gimp,PSP,Photoshop,...
 Signature
As Always B3D
My radio Station…
http://www.pandora.com/?sc=qm81447313#/
http://www.myspace.com/foleypro
http://www.michaelhershman.com
http://www.artwanted.com/foleypro
http://foleypro.deviantart.com/
http://brycepd.webs.com/
Profile
Posted: 29 July 2012 10:04 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Blacksmith - free!
Profile
Posted: 29 July 2012 11:06 PM   [ Ignore ]   [ # 4 ]
New Member
Avatar
Joined  2004-10-05
Ok, thanx gang! Those are some good suggestions. I own PS but not sure if its extended or not, and Blacksmith for free sounds like its worth checking out! Cheers!
 Signature
Profile
Posted: 30 July 2012 07:11 AM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2010-02-05
It looks like the Save/Export function of Blacksmith is disabled, so what good is it other than to see if you like it?
Profile
Posted: 30 July 2012 09:24 AM   [ Ignore ]   [ # 6 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
Sculptris does 3D paint I believe as does Blender
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 30 July 2012 11:46 AM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2003-12-16
I use UVMapper (the free version) and Photoshop. Any version of Photoshop should allow you to open a file, paint on top of it and save it.
UVMapper works on Win and Mac.
http://www.uvmapper.com/downloads.html
 Signature
Gravy to potatoes, Luke to Darth Vader, I’m a souped up sucker and I’ll see you all later
Profile
Posted: 30 July 2012 12:15 PM   [ Ignore ]   [ # 8 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
The desire is for projection painting, so that seams can be painted across, not 2d painting on a template. Fortunately there are now a lot of tools that offer that, as mentioned above.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 30 July 2012 04:38 PM   [ Ignore ]   [ # 9 ]
New Member
Avatar
Joined  2004-10-05
In addition to the tools mentioned (I have not had a chance to examine them, yet), I downloaded Hexagon 2.5 since it’s free from DAZ, and after launching it, there seems to be a full on mesh painting facility, but I’ll be darned if I can make it work. I’m guessing a good four hours of running some tutorials or such would be of immense help here.
 Signature
Profile
Posted: 30 July 2012 09:18 PM   [ Ignore ]   [ # 10 ]
Member
Avatar
Rank
Joined  2005-08-20
The mesh painting capabilities in Hexagon are very very basic. Carrara has better ones and even those are all in all not very good.
 Signature
Profile
Posted: 30 July 2012 09:55 PM   [ Ignore ]   [ # 11 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
actually I find Carrara 3D paint very good but did not mention it as the OP was seeking free programs.
it is dependent on the uv mapping of the mesh used and the texture map size and works best for creating basic outlines to produce a guide for extra detailed work in a 2D image editor like Gimp, MSpaint and ofcourse photoshop which I do not have.
Working with 4000x4000 + pixel texture sizes and a very small brush size I find I can do quite detailed (albeit in my case not terribly artistic) work depending on the uv mapping of the object
there will invariably be seams with some distortion somewhere but altering the uv’s can move those too, I find planar mapping best but often have to change the projection to get a better result.
 Signature
Profile
Posted: 04 August 2012 10:14 PM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2006-05-26
I use Carrara 7 to paint over seams with no problem. I am not sure if it is common knowledge that Carrara paints just fine over seams.
Profile
