Digital Art Zone
1 of 2
1
Toon Shader Problems
Posted: 29 July 2012 11:05 AM   [ Ignore ]
New Member
Joined  2003-10-09
I was trying this process here- http://docs.daz3d.com/doku.php/artzone/pub/tutorials/dazstudio/studio-toonshaders .
I get to this step “Map Settings” drop down menu and select “Ignore” , but the toon options don’t appear in my surfaces, it actually removes everything and all I end up with is UV Set, Smooth, Angle, Diffuse Color and Opacity Strength.
Is there something wrong with the shaders?
Dan
Profile
Posted: 29 July 2012 11:25 AM   [ Ignore ]   [ # 1 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
I Just tested this in DS4Pro and I get the same results as you. It is not accepting the ignore funtuon.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Proud Member of the Bald Wizards Club.
Profile
Posted: 29 July 2012 11:48 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2010-10-10
Works OK in DS3.
Are the shaders compatable with DS4?
 Signature
Wendy
My freestuff: http://www.sharecg.com/pf/full_uploads.php?pf_user_name=Wilmap
My Deviant Art Gallery:  http://wilmap2.deviantart.com/
Profile
Posted: 29 July 2012 11:50 AM   [ Ignore ]   [ # 3 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
They are the Default Shaders installed with DS4. It works fine in DS3 as you said, I tested that also.
 Signature
Profile
Posted: 29 July 2012 12:40 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2005-11-10
The shaders are defiantly not working in DS4 I would suggest submitting a bug report and if you post a link to your report here we can add our confirmation that this is a general bug that is repeatable
 Signature
Community Volunteer:
My DAZ Store
NeilV Poser Stuff & Chohole’s Space
Old Post Count = 6362
Profile
Posted: 29 July 2012 12:54 PM   [ Ignore ]   [ # 5 ]
New Member
Joined  2003-10-09
I just submitted it,
Thanks to all who checked it out and responded so quickly.
Dan
Profile
Posted: 31 July 2012 02:20 AM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2011-05-02
From what I can gather by a little research I do not believe that it is a bug in DS 4 Pro. at all, to put it simply files that are required for the shaders to work are not there.
From what I have found.
A shader in Daz Studio should be composed of:
  a shader definition script, linking the different files bellow
  a RSL surface or light shader (.sdl), which is a compiled version of a .sl surface/light shader code.
  a script defining the shader properties, which means also the user interface in the surface tab
  a render time script run every time the shader is called with attributes passed.
As far as I can see there are no shader definitions for the toon shaders in the DS4 folders and also in the DS4 shaders folder the dztoonskin.sdl is non existent.
It would be nice to have them but I fear we are not going to have such a privilege, it is a business after all.
Profile
Posted: 31 July 2012 04:27 AM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  2005-11-10
TapiocaTundra - 31 July 2012 02:20 AM
They should be there they just got misplace that’s all.  That’s why we suggested doing a bug report so that the developers know that they are missing and can put them back
 Signature
My DAZ Store
Profile
Posted: 31 July 2012 05:18 PM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2012-02-12
NeilV 1 - 31 July 2012 04:27 AM
The shaders are not packed with DS as far as I know and you must get them separately. You can get them here
However there is indeed a bug because the default presets don’t seem to work very well with DS4 because many options are missing. I made some new presets for DS4.5 here.
 Signature
My Deviant Art
Profile
Posted: 01 August 2012 03:38 AM   [ Ignore ]   [ # 9 ]
Member
Avatar
Rank
Joined  2005-11-10
Takeo.Kensei - 31 July 2012 05:18 PM
I will get this flagged up because the presets are installed will DS4 so they should work out of the box not make people jump through hoops especially as we don’t have the DS4 SDK
but thanks for the 4.5 presets I just cant use them yet as a PA I have to stick with the current version of DS4
 Signature
My DAZ Store
Profile
Posted: 01 August 2012 12:36 PM   [ Ignore ]   [ # 10 ]
Member
Avatar
Rank
Joined  2012-02-12
No problem, but I’m not sure these should work out of the box because these were freebies from DAZ for DS3.And a default installation of DS doesn’t come with these shaders so I guess they aren’t officially supported like many other things that need to be updated
What is strange is that other old shaders don’t have this problem for what I know, or I didn’t open my eyes cause I didn’t realize the problem with toon shaders until I saw this thread and investigated on the shader
So it’s a good thing to open a bug report.
 Signature
My Deviant Art
Profile
Posted: 02 August 2012 03:49 AM   [ Ignore ]   [ # 11 ]
Member
Rank
Joined  2011-05-02
Takeo.Kensei - 01 August 2012 12:36 PM
I can qualify NeilV 1 in that the toon shaders are definitely included in the default Daz Studio 4 pro free installation download and by that should be working.
Profile
Posted: 02 August 2012 04:10 AM   [ Ignore ]   [ # 12 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
We have been told that there is already a bug report filed on this issue.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 02 August 2012 12:07 PM   [ Ignore ]   [ # 13 ]
Member
Avatar
Rank
Joined  2012-02-12
TapiocaTundra - 02 August 2012 03:49 AM
Ok I wasn’t sure because I had them since DS3 and they were not included at that time but what kashyyyk describe is exactely what happens when you have the scripts but not the shaders (sdl files)
 Signature
My Deviant Art
Profile
Posted: 02 August 2012 12:36 PM   [ Ignore ]   [ # 14 ]
Member
Rank
Joined  2011-05-02
I said in my post earlier that the definition files to the toon shaders are missing and only one .sdl file. Takeo you must have DS 4, you just made a shader for it yourself, do you not see?
Profile
Posted: 03 August 2012 02:15 AM   [ Ignore ]   [ # 15 ]
Power Member
RankRankRank
Joined  2005-09-05
Please ignore earlier post…realised I had wrong end of the conversation…
 Signature
Shadermixer tutorials and recipes
My Website
My ShareCG Gallery
Shadermixer Documents
Profile
1 of 2
1
