Digital Art Zone
distorting body parts
Posted: 27 July 2012 05:04 PM   [ Ignore ]
Member
Rank
Joined  2008-11-11
Any ideas on what may cause this after a preset pose is applied?
Profile
Posted: 27 July 2012 07:40 PM   [ Ignore ]   [ # 1 ]
New Member
Joined  2011-07-01
I have a possible idea what causes it, but it only seems to happen to me when I use a pose made for M4 or V4 on Genesis- I think it’s something about the zones not being the same. You are talking about distortion in the hands/feet most often, correct?
Profile
Posted: 27 July 2012 08:14 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2008-11-11
Yes, its just the hands and feet. I did find a script here:  http://www.daz3d.com/forums/viewthread/306/  thats fixes the problem. Its the second one down under the freebies if you need it.
Profile
Posted: 28 July 2012 03:43 AM   [ Ignore ]   [ # 3 ]
New Member
Joined  2011-07-01
You sir are a magician. Thank you -so- much. I know several people who want this. XD
Profile
Posted: 28 July 2012 04:32 AM   [ Ignore ]   [ # 4 ]
Power Member
RankRankRank
Joined  2005-09-05
Dare Arkin - 28 July 2012 03:43 AM
As well as the hands and feet the arms and legs can sometimes distort because the bones have not altered sufficiently when a large amount of scaling is involved. I’ve recently dicovered that if you click on the icon for bones you can see if the bones being too low or too high is what is causing the problem. Then right click on the bones go to edit and choose align to body shape this seems to snap the bones back to where they should be and also corrects the distortion.
 Signature
Shadermixer tutorials and recipes
My Website
My ShareCG Gallery
Shadermixer Documents
Profile
Posted: 28 July 2012 03:31 PM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2005-10-26
This is caused by using Gen4 poses on Genesis. The models have different bone structures and so the poses are not fully compatible.
The fix previously posted will help to correct the problem.
I haven’t yet figured out how to save pose presets in DS4, but if you do you could use the pre-genesis pose, use the fix and then save as preset for use later.
 Signature
Old post count 4147
MY DA Gallery : http://flashback37.deviantart.com/
Profile
Posted: 28 July 2012 05:31 PM   [ Ignore ]   [ # 6 ]
Power Member
RankRankRank
Joined  2005-09-05
flashback - 28 July 2012 03:31 PM
I have also seen this occur while using Genesis poses…that is what my fix above is for .
It seems to happen when the rigging is out of alignment, so far I’ve only seen it where I have used extreme scaling,I suppose that is why they have allowed the ability to create rigging for different shapes.
I am posting some pics of Genesis prior to using my fix and the same figure immedieately after applying my fix.
One note, I did make an error in my description of the selection after edit it should read adjust rigging to shape not align to body shape as I had previously written.
Image Attachments
 Signature
My Website
My ShareCG Gallery
Profile
