bobh - 20 September 2012 08:40 AM
PhilW - 19 September 2012 04:08 PM
Bobh, The Jeremy Birn book is very well known - a good choice and I am sure that you will pick up a lot from it.
I already am - thanks, PhilW. And by the way, I’ve also purchased both of your Infinite Skills tutorial sets. Excellent “hit the ground running” stuff, hopefully I will get good enough to actually need the advanced set.
Good man!
The first set is more about the individual features, while the “Advanced” set goes more into modelling and working on specific projects, so you should be able to dip in and out as you see fit, once you have the basics under your belt. Actually I wanted to call it “Carrara Projects” rather than “Advanced Carrara”, but Infinite Skills made the final decision on that!
