I have a couple of boat figures from DAZ (AE Boat and AG Boat), and I need to set the Hot Point of the Model to match the center of the model. I’m able to do that at the root level, but when I go to the model level, the center and hot point don’t match, and all of the parameters for hot point and center (and orientation, rotation, size and scaling are grayed out and inaccessible).
I’ve tried unchecking Lock Hot Point and down at the bottom of panel have changed the Lock to Object Center Only (Other options being Hot Point only or Hot point and Object Center)
Is there a way to force the Center and Hot POint at the Model Level (as opposed to Root level) to equal one another?
(I need to do this for a workaround for a problem with a plugin)
Thanks
