Hi AtticAnne
Stick with the most recent,.. 172
they should both work with the same serial (expires December) but 132 would have bugs which may have been fixed in 172.
so,.. 172 should be the build to use for testing. (if you have it)
I’m not entirely sure why the 132 build is being added to accounts, but I’ll try to find out.
Carrara doesn’t have a Log file,. it creates a Temp file, for work in each scene, and (Importantly) this sometimes remains in the DazTemp folder,. after a crash,..
So,.. you should check this folder occasionally, to see if temp files are being left after any crashes, lock-ups, forced quits, etc..
You can delete any files that are there,. as long as carrara isn’t running at the time.
the path is C:\Users\YourName\Documents\DAZ 3D\DazTmp on PC.
If you have an issue with something, and it’s repeatable,. Start a new thread about it, and I’ll try to help,.. or post a Bug report .
