Question for those of you who assign categories to all your content:
Do you prefer to have the various materials/textures associated with a particular item shown in a sub-folder within the item’s own category folder (one level farther down the folder tree), or do you simply have all of your textures categorized under “presets/materials/[name of prop].”
Because so much content lacks Metadata, I just spent MANY hours finally going through ALL my Daz & Poser content folders & manually assigning categories to everything that didn’t already have at least one. This has been an improvement over searching for stuff blindly & trying to remember what content is where, but I can’t help thinking that it would be even better if I had done it differently: i.e. if I had put all those texture options into new sub-folders co-located with their respective prop/item under the Props/ or Sets/… branches of the folder tree instead of under the Presets/ branch. But fixing/adding those new categorizations now is going to mean another marathon of mouse-clicks for me… Will it be worth it?
Is there a better way?
Advice from those more experienced would be appreciated. I am using DS4Pro 64-bit on Win7. Thanks.
I hate to say it but, YES I do that myself. All content for one item in one easy to get to place, right next to the item. Once you start this you must keep it up or you get way behind very fast. But why hunt in another catagory for those cool textures if you can just load them one or two clicks after you load the item? I also have large catagories Such as Furniture Indoor with sub catagories under those. It does make for much faster scene design and set ups.
Yes, I have all textures as subfolders of their parent item, this includes having a ‘characters’ folder under each of the base figures. I also drag all props items over to the characters folder hierarchy so that props associated with an outfit are in the same folder as the outfit itself. I also do the same for associated poses and merge Poser and Daz versions of the same textures if the PA hasn’t done it so that the DAZ version will be automatically picked up by Studio when I select the texture.
Setting it up initially is a faff, but I’ve been doing it this way for several years now and it means that when you are actually doing something creative, you don’t have to think about whether there is a texture you can use, it is right there for you. If you get into the habit of moving files as soon as you install them, then there really isn’t that much of an ongoing overhead. I’ve never used metadata/smart content, because what it was trying to give to people I effectively had already.
Other props (like shoes, jewelry and such) I put in a more generic set of folders. The textures still stay with the base model.
Same with poses. I put all the poses in sub folders (like Victoria, Michael) but label where they came from (if associated with a specific model or set.
I haven’t played with the metadata much… too set in my old ways.
I always call my Textures, Lights, Props, Pose, Character the exact same name for that particular product. So if I load the character called Mary, I know the textures for it will be under the name Mary. If the set has props it will be under Mary. Its just easier to remember it that way. I always extract to a folder on my desktop and rename before it goes into my runtime or library. But everyone has their own method…
I do this also my main gripe with ds4 is that they’ve restricted the ability to move/delete some folders. I have my own system which is admittedly similar to theirs , but I prefer my own. Everything is organized so that I can easily find it. When you own gb’s of content it is too easy to forget which textures you have for an outfit if they are all in the same folder it’ s less of an issue to find stuff.
Yes indeed. I categorize every product from the studio and poser subfloders into categories. Main Product gets in an assigned category and I put all textures and props related to the product in subcategories. I may also categorize a part of the product to another category if it is relevant for that category. When I buy a new texture set for a product I put it also in a subcategory of the main product. Works well and I can easily find a Product and all what was made for it.
Definitely makes sense to categorize all elements of a given item together. The odds are pretty good that’s when you’d use them, thus saving time, instead of searching for them in other areas.
Yep, everything, materials, associated poses, props, lights, cameras etc. that belongs to one item are being put into one folder / subfolder. Due to the way I organize my stuff, I may copy some items to a separate folder (so I have, lets say, jewelry props from one outfit in both the outfit’s folder and in an own separate folder in my ‘Jewelry’ section), but there’s always one ‘main folder’. I really hate spreading content over several folders, but from what I understand, the way Poser, at least older versions are set up, content creators kind of have to.
my main gripe with ds4 is that they’ve restricted the ability to move/delete some folders..
Categories or Folders? I never touch the folders in the Studio and Poser file system. I let products install stuff wherever they want. It is easier to update them doing this. Once the stuff is categorized or ignored I don’t look at those files anymore.
The categories system (except unassigned) can be organized exactly the way you want it.
Yes, yes, yes… I now always group the associated files as subfolders. Also add in the artists name so I can search that way as well and cut and paste key information from the product page into the notes field. And then backup religiously my Content Manager Database. There’s a lot of hours of work invested in it now.
Nothing more frustrating than finding a texture you want to use and not being able to locate the associated mesh when you’re on a creative role! This little bit of work up fronts saves hair pulling down the line for sure. Good idea to post this and share ideas.
I do the same, I have an Accessories folder, with subfolders for jewellery, handbags, watches, glasses and so on, it makes it so much easier to completely outfit a character. Another thing I’ll often create duplicate copies of to group together under a single folder is footwear, just because shoes or boots come with a particular outfit doesn’t mean they can’t be used with something completely different.
Wow, thanks everyone for all the replies (& PMs). Seems like most of you like to keep everything (presets, materials, sub-props) co-located with its parent mesh.
Thank you! Looks like I have some more work to do… but in the end I agree it will be worth it. I think I have a couple hundred Gig’s of content. Already I am finding products I had forgotten about that I could have used in previous renders. Assigning multiple categories to certain items that are versatile is becoming one of my favorite tricks.
One of these days I’ll finish all this & be able to get back to rendering.
PS: Once all this work is done, are there any special steps I need to take to make sure my categorizations survive the inevitable version-upgrade to DS4.5? I’d REALLY don’t think I could re-do all this if it ever gets wiped out.
