How do I load a .dsf morpg file into a scene?
Lets say I've created a scene with a Genesis figure. After I created the scene, I've made some some new morphs for the genesis figure. When I load the daz scene file, the new morphs I created since making the scene don't show up - only the morphs that were in place when I created the scene. How can I make the program import a dsf morph file in to the scene? Please don't tell me I have to convert them to objects and load them with morph loader.
  • adamr001adamr001 Posts: 22
    Add a new genesis to the scene, remove the old one, undo the remove, the old one should then have the new morphs, remove the new one, continue on...
  • edited December 1969
    That didn't work for me. The new Gensesis has the new morphs and they are only available for that Gensesis, not the original in the scene. When I delete the original and undo the delete, the morphs are still not available for that Genesis.
    Its just seems they's be a way to import a dsf morph file.
  • Richard HaseltineRichard Haseltine Posts: 41,893
    That's not quite it - select the old Genesis, double-click on the base Genesis in the library and when asked what you want to do choose to apply it to the current figure rather than loading a new figure, then undo to get the pose and materials back (or save and then apply a .duf/.dsf character preset).
    Whoops, sorry about that. That's what happens when I go from memory instead of doing it as I type.
    Hooray :)!
    That did it, thanks to both of you .
  • spacecat56spacecat56 Posts: 42
    ... select the old Genesis, double-click on the base Genesis in the library and when asked what you want to do choose to apply it to the current figure rather than loading a new figure, then undo to get the pose and materials back...
    I suppose it's good that there's a way to do this. But as a sw development pro I will say that it seems like an exploit and seems pretty cheesy. To get the desired effect - new morph on an old figure - you are counting on the Undo not really working 100%. A correctly working Undo would not have the effect you want; it would, um,undo everything. And the fact that undo does not work correctly in a number of cases is a bug (well, a number of bugs) and should be fixed at some point, no?
    The exploit you describe would have saved me some script time... for somewhat similar case I wrote a "subMeIn" script to copy all the poses etc to the new figure, after running the script I delete the old figure and go forward with the new one. Though I've had to delete and re-create all clothing items too; after once invoking "Apply smoothing modifier" on a piece of clothing fitted to a figure, it seems nothing I can do will make that piece of clothing ever work correctly with a different figure. Even so, my script has been useful to me and I learned yet a bit more in the process.
    I'm not sure it's a bug - generally Undo doesn't undo adding stuff (you can't undo loading a figure or prop, though you can undo adding a DForm) so it may be designed to work that way. You can also, as I said, avoid the undo set by saving a dsf/duf character preset which will refresh but reapply the existing settings.
  • Hey, I finally figured out how to get a .dsf 3rd party morph to load into Daz 4.9.  I thought I'd tried everything.  Then, I was hunting for anything and right clicked on the dsf file I had copied into my Figures/Genesis 2 Female/Characters folder.  I went to the bottom selection "Create Custom Action."  I did that, then went under the "Scripts" on the main menu bar and there it was.  I clicked on it under "Scripts" and the morph finally showed up under my "Actors" in the "Shaping" tab.  I swear, I didn't find anything on any site or video to tell me how to do this.
    I'm posting this in case it helps anyone else who's struggling with 3rd party morphs.
    Eric
  • If it's a morph asset it shouldn't be in the \people folde at all - it should be in \Data\DAZ 3D\Genesis 2\Female\Morphs\Some folder.
  • If you could point me to the correct tutorial or page info, that would help a lot.  After placing the files in just about every possible folder, using the "Create Custom Action" was the only method that actually made the DSF do anything.  Otherwise, I could drag it and apply to figure all day long - no errors, just also no effect.
    I'm sure experienced users must know how this is supposed to work.  But, I have had no other success.
  • Is this a freebie? if so, do you ahve a link?
