Digital Art Zone
Missing step with clothes. Please help
Posted: 23 July 2012 12:32 PM   [ Ignore ]
Member
Rank
Joined  2006-05-09
Hi All.
I have loaded Michael 4 into Carrara 8.5x and would like to put conformable clothes on him.
I am wanting it to be a biblical character and so I have purchased a dynamic robe…
What are the specific steps for making this “prop” conform to and pose with Michael?
I know how to do it in Poser, but I think I am missing something in Carrara.
Thnx!
Profile
Posted: 23 July 2012 12:57 PM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI Realtime smile
Any “Dynamic” item is usually a dynamic / simulated cloth. and as such, they’ll only work if the program has a physics Dynamic Clothing simulation feature, such as Poser’s Cloth room, or the dynamic clothing plugin for Daz Studio.
You would need to Simulate the dynamic cloth there,. then transfer the results to Carrara, to render it.
There’s a python script for Poser (Dyn2Morph) which will convert the Dynamic cloth simulation data into a set of Morphs which all export out, and that can be used in Carrara, although, at that point, the dynamic clothing is no longer dynamic,.. it;s an object with a set of animated morphs, so no further cloth simulation can be done on that item within carrara.
As far as I know,. there are still some issues with transferring dynamic cloth simulations from DS to Carrara.
but those are being worked on as part of the beta development for C8.5
Hope it helps
Profile
Posted: 23 July 2012 01:13 PM   [ Ignore ]   [ # 2 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
you can line the object up to fit the figure in a t-pose then select it, hold shift and select the figure’s hip and go up to the animation tab and choose attach skeleton.
then the figures bones will move the vertices like conforming clothes.
it may need weightpainting.
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 23 July 2012 01:16 PM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
an example using prop hair http://www.youtube.com/watch?v=8mpWQwSxH_M
same principle
 Signature
Profile
Posted: 23 July 2012 08:25 PM   [ Ignore ]   [ # 4 ]
Addict
RankRankRankRank
Joined  2004-07-21
Which robe did you get?  Is it made for poser or ds?
 Signature
Hello, Sweetie!
Profile
