Digital Art Zone
Broken content links
Posted: 23 July 2012 08:26 AM   [ Ignore ]
New Member
Avatar
Joined  2008-09-19
I have a few content items that have broken links, so to speak.  I.e. the content is still there (but the location or path has changed for some reason? in any case I can’t access it in the usual way).  Here is an example (attachment) - could someone suggest a way to fix this?
Image Attachments
Profile
Posted: 25 July 2012 02:30 PM   [ Ignore ]   [ # 1 ]
New Member
Avatar
Joined  2008-09-19
To fix this: right click on the broken link, then:
database > preferred file > (choose the correct file)
This is a bit tedious (since I have dozens of problem links like this) but it works.
Profile
Posted: 26 July 2012 02:41 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2007-01-08
I don’t use the Categories, so it’s good to hear that yo found a way to fix it. But what strikes me is the (3): prefix on all those files, which in the other areas of content indicate it’s the third copy (or install) of a product. As “general advice” I’d first check to see if the original install is still there to avoid multiple content counts.
Profile
Posted: 26 July 2012 05:26 PM   [ Ignore ]   [ # 3 ]
New Member
Avatar
Joined  2008-09-19
Good point.  When I go to “database/preferred file” I can see all the folders where the item exits - all but one are backups on external hard drives etc.
Profile
Posted: 04 October 2012 12:26 PM   [ Ignore ]   [ # 4 ]
New Member
Joined  2006-05-12
I don’t get the option.  There is a submenu indicator for database, but no submenu opens.  I’m on DAZ 4.5 64-bit PC build 114.
Profile
Posted: 04 October 2012 04:33 PM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
The (3) in front of the name of each item means there are 3 locations referenced for each.  Select all, right-click and choose “Remove Orphaned References” and you should just have the correct one.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
