Richard Haseltine - 23 July 2012 05:13 AM
As evilgidget says, 4.5 uses place-holders sized for an item’s bounding box if iot can’t find the actual content. Of course if you are opening scenes on the machine they were created on there shouldn’t be missing content, unless you’ve changed the directory set up. If you are losing scene eleemnts when you shouldn’t be, what OS are you running and what are your content directories?
Thanks all for the comments.
I think it usually occurs when I open a scene I created on the same machine using DS3A and opening in DS4.5.
