Digital Art Zone
Content tab issues
Posted: 22 July 2012 08:53 AM   [ Ignore ]
New Member
Avatar
Joined  2008-09-19
I have been away on holiday for a month or so.  When I got back (day before yesterday) I started using DAZ Studio 4 as usual. Everything was fine at first. This a.m., however, I can not find my content categories for some reason. ( I must admit I don’t really “understand” the inner workings of the content library - I just set things up a year or so ago and used it with no problems.)  So - I think what I need is to “view categories as tree” - and I think the folders I so carefully organized should be under “Categories - default” etc etc.  But this is what things look like (attachment) - there is nothing under categories for some reason.  Also - when I install new content and “scan know directories for files” - nothing seems to happen at all.  I.e. my new content should show up, highlighted, under Categories somewhere - but nothing seems “normal” for some reason.  Help!
Image Attachments
Profile
Posted: 22 July 2012 09:11 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
When you install new products in DS4 they will show up in either Poser Formats or Daz Studio Formats or both. They will not automatically be assigned to a Category, we have to do this ourselves manually. Like we did in DS3.
If you have DS3 and you sorted them into categories then you can use the “Migrate Old Content Database” command (it is in the same menu as “scan know directories for files”).
To give you a better understanding the Poser and Daz Studio Formats there just are a mirror of the content folders on your Hard Drive. These are connected you the “scan know directories for files” command.
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 22 July 2012 10:47 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Is your DAZ Content Management Service running?  If you stop it (Windows start button > All Programs > DAZ 3D > DAZ Content Management Service > Stop DAZ Content Management Service)  then your Categories folder will go blank like this.  Perhaps it isn’t starting correctly, got accidentally uninstalled, or is otherwise blocked from communicating with DAZ Studio in some way.
Profile
Posted: 22 July 2012 11:09 AM   [ Ignore ]   [ # 3 ]
New Member
Avatar
Joined  2008-09-19
Content Management Service - yes, that fixed it!  Thanks so much!
Profile
Posted: 22 July 2012 11:46 AM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
Sean Riesch - 22 July 2012 10:47 AM
I had no idea it effect Categories too, thanks for that nugget. Bookmarked for others. smile
 Signature
Pete
My Render Thread
Profile
