dissapearing tabs
srieschsriesch Posts: 3,418
I have my Windows 7 64-bit PC set up with the main studio window on the left monitor and a lot of tabs on the right monitor. Every so often when I start DAZ Studio, all the tabs on the right monitor are gone. I have to open them again, and they start out at the small default size. Any idea what I might be doing to trigger this, if anything?
  • JaderailJaderail Posts: 0
    DS stores the layout you have at close. And then opens with the same Tabs ect...
    Is this what you are seeing? If you Close a window it's gone, if you leave one open its still open. That's what I see every time. I have to set it to what I expect before I shut down.
  • srieschsriesch Posts: 3,418
    I am not closing the second window with the tabs in it. When I exit DAZ Studio, I close the main window. The tabs in the second window return on startup most of the time, usually for weeks or months before it suddenly resets.
  • FixmypcmikeFixmypcmike Posts: 16,600
    Save your layout so that you can easily restore it when this happens.
    That has happended to me before, I did not understand untill you said it works for awhile and then just disappears. I do as Fixmypcmike says and even copy a backup of the layout file to another folder. I have had my setups get randomly replaced with the setup at close. I think it happens during large file saves but I can not prove it.
    Thanks, I'll start saving my layout for quick recovery until I can find out for sure what's causing this and resolve it.
